Author Topic: 75 CB360 - bad omen "yatagarasu" build  (Read 39931 times)
Offline MiniatureNinja
Re: 75 CB360 - bad omen "yatagarasu" build
« Reply #290 on: May 20, 2018, 23:51:45 »
One last thing, piston rings in correct order and orientation? These are Suzuki ring sets, and they aren't like the Honda ones, so I'm not sure what order to put them in
'75 Honda CB360 - thread
Offline irk miller
« Reply #291 on: May 21, 2018, 00:12:46 »
What direction is the angle on the middle ring?  Sometimes the upper and lower ring (or upper and lower lip) on an oil ring is an angle similar to the middle ring in the pic.
« Reply #292 on: May 21, 2018, 00:38:23 »
this is what baffles me, I have 3 sets of rings, two aftermarket and 1 suzuki.. none of the rings are tapered
*EDIT:
ok it looks like according to this: https://www.manualslib.com/manual/1076648/Suzuki-Gs850g.html?page=83#manual
that I have mine backwards. either the taper is so small that I cannot discern it, or the ring isn't tapered, which concerns me a little - but both rings have the "r" so I'll just face that up"
« Last Edit: May 21, 2018, 15:13:51 by MiniatureNinja »
Offline crazypj
« Reply #293 on: May 22, 2018, 09:27:30 »
The taper is too small to see.
Any numbers or markings go up. Top ring is light grey on outside edge.If you've had motor running you may see a faint 'shiny' line at bottom edge of middle ring (or top if it was upside down) Just looked at pic, you have top and middle rings in wrong places The 'chrome face' of top ring is clearly visible.All Japanese manufacturers have used very similar lay out since at least mid 1960's
I only 'recently' found out the various letters used are not what I was told40+ yrs ago but are the various piston ring manufacturers (Riko is the only one I remember at present, they stamp an 'R' on top of stock size rings) You can also get S, N, A, O (and maybe others?)
« Last Edit: May 22, 2018, 09:38:12 by crazypj »
Best thing I ever overheard
Brian Morgan, 1982
« Reply #294 on: May 22, 2018, 11:52:45 »
Thanks, I got it now :)
Everything back together correctly and just pending my final part (stupid top tensioner bracket) will literally be starting the engine the day of the bike show. Ugh
Offline crazypj
« Reply #295 on: May 22, 2018, 12:15:39 »
That looks better.  8) You have fitted all the circlips?
Brian Morgan, 1982
« Reply #296 on: May 22, 2018, 14:57:23 »
Yes, dont make me tear the engine apart again!!!
I'm driving to the shop to install it in the frame
« Reply #297 on: May 23, 2018, 02:16:00 »
Lots of progress made tonight. Still a ways to go, wiring, startup, tuning, timing, exhaust. But I am very excited about where I'm at now.
Also, a look at the micro tacho that's mounted under the tank.
Oh, and why not the project that's waiting for "yatagarasu" to be done so she can get some attention.  82 BMW R65LS
Offline crazypj
« Reply #299 on: May 23, 2018, 11:17:14 »
You'll probably get pissed off with tach in that position pretty quick. Beemer is great bike to work on. there were plenty of 'Endurance racers' around back then (although mainly 750 & 1000) so all the 'work' on what needs doing to 'CAFE' it has been done
Brian Morgan, 1982
