Author Topic: 75 CB360 - bad omen "yatagarasu" build  (Read 37890 times)
Offline MiniatureNinja
Re: 75 CB360 - bad omen "yatagarasu" build
« Reply #300 on: May 23, 2018, 14:18:32 »
You'll probably get pissed off with tach in that position pretty quick. Beemer is great bike to work on. there were plenty of 'Endurance racers' around back then (although mainly 750 & 1000) so all the 'work' on what needs doing to 'CAFE' it has been done
Why is that? It doesn't hit my knee, wont be turning to lock while riding really. Not super concerned with being able to see it while riding as I can feel/hear engine rpm anyway.
All that work on the Honda and everyone loves the BMW.
'75 Honda CB360 - thread
Offline irk miller
« Reply #301 on: May 23, 2018, 14:36:16 »
Well, I have two BMW motorcycles.  I also have a 360, sooooo.   ;)
« Reply #302 on: May 23, 2018, 15:06:50 »
After mocking up the subframe of the BMW I might like it too. Hahaha. Too bad it's being built for a friend
« Reply #303 on: May 28, 2018, 16:23:25 »
Everything seems to be taking an hour longer than it should on this thing. Not much progress was made overall but got some things done this weekend
Headlight mounted, plate and tail lamp mounted, engine buttoned up with tensioner, tank mounted, ignition coils and master cylinder mounted, chain on... decided the gold chain was stupid got a regular one. still need to wire it and make a cable for the front brake.
« Reply #305 on: May 28, 2018, 22:04:17 »
That's not a Georgia tag izzit?
no i'm in CA... which sucks because I really need to get out and ride... been perfect weather since December. LOL
« Reply #306 on: May 30, 2018, 19:26:12 »
I hate this part.
99% there
Offline crazypj
« Reply #307 on: May 30, 2018, 23:23:29 »
You really want bike leaning about same angle but to right side. When oil level is correct you will have it 'leaking out' when stator cover is removed. I use centre stand with a 1" thick piece of wood under left side then pull it back off when I'm done
Best thing I ever overheard
Brian Morgan, 1982
« Reply #308 on: May 30, 2018, 23:40:37 »
how could it lean the other way it would fall over?
there is no oil in the bike ATM - just buttoning up the wiring
Offline crazypj
« Reply #309 on: May 31, 2018, 11:22:48 »
Yep, without  a center stand it falls down. Block under clutch cover or  'tie' it to a wall stud when your working on it with oil in engine
Brian Morgan, 1982
