Author Topic: 75 CB360 - bad omen "yatagarasu" build  (Read 39048 times)
Offline crazypj
« Reply #50 on: Jan 18, 2018, 16:33:19 »
I've only ever used 17/34 sprockets. 37  rear may be too much with extra 22cc. You have already got clutch springs from BorTec?
Best thing I ever overheard
Brian Morgan, 1982
Online irk miller
« Reply #51 on: Jan 18, 2018, 16:35:30 »
They shift way too short with the bigger sprocket, too.  At least the 42t.
Offline MiniatureNinja
« Reply #52 on: Jan 18, 2018, 16:58:49 »
I ordered Barnett clutch springs, BoreTech seams to be going out of business, selling what's left only.
I have a 35, and 34 tooth sprocket already, so I will have the ability to change things up if I need to - 520 conversion BTW
« Last Edit: Jan 18, 2018, 17:12:20 by MiniatureNinja »
'75 Honda CB360 - thread
Offline crazypj
« Reply #53 on: Jan 18, 2018, 23:26:57 »
Cool stuff, I'm doing 520 on 'Blue Bike' to get the extra tyre clearance
Brian Morgan, 1982
« Reply #54 on: Jan 20, 2018, 00:52:24 »
pre-cleaning. Anyone got a recommendation for sending heads out for valve seat work and installing new guides? I think the guy I have locally will do it for $250 which I really dont want to have to buy the tools as much as i want to do some things myself, even the installation of guides will require tools I don't have
Since I plan to port the head I think I should also do this BEFORE I get service done, right?
« Reply #55 on: Jan 20, 2018, 17:42:18 »
Not sure how to tackle this should I grind these off and how?
Online irk miller
« Reply #56 on: Jan 20, 2018, 17:49:01 »
There's a strong argument for keeping the center stand brackets.  You can slide the pin out and remove the center stand for riding, then put it back in when you need to service the bike.  I kept mine.
Offline trek97
« Reply #57 on: Jan 20, 2018, 17:52:32 »
Centerstand clamps.  Absolutely NOT.  Keep them for service, carb tuning, chain adj,  tire work, etc.
I have my center stand sitting on the shelf.  Stick it on just when needed w a 5/8 x 7" bolt, no spring or nothing.  I don't even bother putting a nut on the bolt.
« Reply #58 on: Jan 20, 2018, 18:11:48 »
bike never had a center stand, will have to find one - I realized it will make some things easier to maintain if I keep the loops and just make it removable like suggested
so what I did was cut off the "stop" and the spring holding loop, then ground the little bump on the bottom off nice and flush so it's a little less noticeable
going to weigh the frame tonight wheni get home - curious how much a stock frame weighs (as in I should have weighed it before I startet cutting and grinding)
« Reply #59 on: Jan 20, 2018, 18:51:21 »
what size tire? I was able to get about 1mm clearance with a 130 tire on the 360 with stock rear rim.
Not going to do that, 110 rear I think with a 2.15 rim. Not sure yet
