Author Topic: 1980 CB900F Build  (Read 6394 times)
Re: 1980 CB900F Build
« Reply #60 on: Aug 06, 2018, 06:18:36 »
White trace! On the wires! thanks CXman, turns out I had them backwards. My god I have awoken a beast, I got so used to it running on two cylinders that when I finally got it going on four I couldn't believe the noise and revs I could achieve.
Now I have to order float needles and a fuel tap to stop the two petrol leaks I have. Also I will look at getting some new cables custom made to fit.
A knight in shining armour is a man who has never had his metal truly tested.
Offline cxman
« Reply #61 on: Aug 06, 2018, 07:55:39 »
they are a blast to ride just wait i love mine
1978 CX650 Super Deluxe
1979 XS1100 Special
1974 xl350
1983 cx650 Custom
1973 cb750
1980 cb750
1981 cb650
1982 cb900 c
1974 kawasaki 350 bighorn
1983 GL1100 aspy full dress
1983 GL1100 Nekid
and a bunch of others
« Reply #62 on: Oct 12, 2018, 03:27:58 »
What adventures I've had! So I got the new float needles and stopped the leaking from there and also put a new fuel tap on and stop the petrol leaking from there too but now its weeping out of the carby bowl. (Pictured) I have ordered new gaskets for them. One day this bike wont leak fuel!
I sent the cables away to get shortened and they come back a perfect fit! pays to measure things twice.
The fuel temp sender that I put in the sump is also leaking oil. (Pictured)
Bike stopped charging so I replaced the coil and now its working.
I have been for a few short rides and just the other day it sounded a bit "crunchy". I thought that the chain might have a seized section in it so I rolled it on to the hoist to check it but before I could get it on it stopped rolling dead in its tracks. Turns out the front caliper bolts were only hand tight and the nuts had fallen off, the bolt was sticking out hitting the forks! Glad I worked that out in the garage and not on the road. So now I have to order a new bolt and some nuts.
« Reply #63 on: Oct 12, 2018, 04:32:23 »
Correction - Rotor bolts, not caliper bolts.
Also looking in to a fork and swing arm conversion next winter. Taking ideas now though.
Online advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #64 on: Oct 12, 2018, 10:52:22 »
Damn, you got lucky on that rotor bolt. Make sure to loctite those when you reinstall. Use the Red stuff.
For the leaky sender on the sump, next time you do an oil change (after you've drained the oil), clean everything with acetone or alcohol. Then use some Yamabond, a tiny bit on the threads and some on the sealing surface to seal it up. Let it set up overnight before you fill it with oil again.
Offline VintageMBike
« Reply #65 on: Nov 04, 2018, 19:56:25 »
I can appreciate the hard work that went into the bike, but Im a purist. I have a 82 CB 900F and the most I did was put on red s/s brake lines, and CR carbs. Not knocking your fine work at all, but I dont know why ppl chop these things up.
« Last Edit: Nov 04, 2018, 23:19:42 by VintageMBike »
1977 Kawa KZ650
1977 Kawa KZ750 Twin
1972 Honda CB 750
1973 Honda CB 500F
1982 Honda CB 900F
Offline Popeye SXM
  • Also used for MX
« Reply #66 on: Nov 04, 2018, 22:04:13 »
Quote
CB900's are great bikes. For me Tim's is cleaner and better looking but that is what customising is all about, making it yours. Nothing wrong with original. I am pleased to see these great bikes being enjoyed
Offline cxman
« Reply #67 on: Nov 04, 2018, 22:33:25 »
nice job glad you got it sorted its a wonderful bike and a lot of fun
1979 XS1100 Special
1974 xl350
1983 cx650 Custom
1973 cb750
1980 cb750
1981 cb650
1982 cb900 c
1983 GL1100 Nekid
« Reply #68 on: Nov 04, 2018, 23:04:24 »
If you were responding to me, yes its an AMAZING bike. I love that "WHOOOSH" that happens just after 6,000 RPMs Truly a fun bike.
1977 Kawa KZ650
1972 Honda CB 750
1973 Honda CB 500F
1982 Honda CB 900F
