Author Topic: Custom Racer with Aluminium Frame and Sportster Engine  (Read 7672 times)
Offline stroker crazy
  • crazy as a fox
Re: Custom Racer with Aluminium Frame and Sportster Engine
« Reply #10 on: Jan 17, 2018, 03:53:44 »
There is no way I am going to miss this!
Crazy
“Ride like the Wind” W.H.
Offline doc_rot
« Reply #11 on: Jan 17, 2018, 05:46:24 »
this shaping up to be legendary. What alloy are you using for the chassis? nice work!
Offline DM_Andreas
« Reply #13 on: Jan 17, 2018, 10:39:50 »
It's all 6061T6
Quite strong and easy to work with...
T6 is heat treated for better strength. If you weld that, you'll loose a bit of its attributes in the welded area.
After the welding we temper the parts once for 2 hours at 210C.
That reduces the effects of the welds in the heat affected areas.
We usually reach results which are comparable with a T4 Temper and that luckily directly at the weld.
With good heat managment it doesn't influence the overall structure.
Offline DM_Andreas
« Reply #14 on: Jan 17, 2018, 10:52:44 »
Let's do an update...
Here are the finished Axle-Mounts....
Offline canyoncarver
  • 'hacking is learning'
« Reply #15 on: Jan 17, 2018, 12:33:34 »
I dig projects like this.  I'm in.
Offline killerx
« Reply #16 on: Jan 17, 2018, 16:05:17 »
What machine are using to make this?
05 Victory Hammer(110hp 115tq @ the wheel)
73 Honda Cl350(Haven't decided what to do with it) SOLD
75 Suzuki GT380
Too much of everything is just enough.
Offline WhyNot
  • ~~~If it ain't raining, I'm riding~~{iii}?~~prost~
« Reply #17 on: Jan 17, 2018, 16:35:42 »
I'm in............................just wow.......!!!!!
2015 Toyota Taco DD now
2006 Harley Davidson Heritage Softail
1975 Honda CB750K5 needs carb work
1974 Honda CB350F2 needs tins painted (being lazy)
1972 Honda CB175K2 roller no engine
1972 Honda CB/CL350 Engines need roller
1972 Honda SL350K2 Frame for above engine
1972 Honda CB100K2 needs kicker shaft
1990 Mitsubishi MM runs, but no power
1984 Dodge D50 Beater was DD since 1997
Offline Tim
  • Administrator
    • DO THE TON
« Reply #18 on: Jan 17, 2018, 17:08:34 »
Pretty amazing stuff - looking forward to progress on this!
Offline SF
« Reply #19 on: Jan 17, 2018, 18:17:07 »
Are you going to polish the frame and swingarm or keep it machined? I like the machines look myself up, looking great so far
72 R5
75 CB550 PROJECT
72/73 S2 RACE BIKE
72 CB350 MOM'S BIKE
