Author Topic: question for machinists  (Read 1585 times)
Offline doc_rot
« on: Jan 24, 2018, 01:31:32 »
I need to bore this needle bearing inner race from 16 to 17mm. A carbide boring bar wouldn't cut it at all. I'm thinking about making a tool holder for a dremel and putting a sanding drum on it. what should i do?
Offline Tim
  • Administrator
    • DO THE TON
Re: question for machinists
« Reply #1 on: Jan 24, 2018, 02:19:15 »
Buy a replacement bearing with the right dimension race?
Offline doc_rot
« Reply #2 on: Jan 24, 2018, 02:32:56 »
I looked but its a weird size. The needle bearings are 25x32x30 and the inner race needs to be 17x25x35 or could be 17x25x30
Offline J-Rod10
    • Slipstream Cycle Works
« Reply #3 on: Jan 24, 2018, 08:44:56 »
What is that made of that carbide wouldn't touch?
Offline SONIC.
« Reply #5 on: Jan 24, 2018, 09:50:48 »
Adamantium
Beat me to it you bastard.
Offline J-Rod10
« Reply #6 on: Jan 24, 2018, 11:30:50 »
Probably give ceramic a go on the Wolverine claw bushing.
Offline Pete12
« Reply #7 on: Jan 24, 2018, 18:52:34 »
I made a tool post holder for a die grinder with a cylindrical stone to grind my chuck jaws. I angled it very slightly to cut on the leading edge and it worked perfectly.
Offline J-Rod10
« Reply #8 on: Jan 24, 2018, 20:02:51 »
Poor mans tool post grinder. Well done.
*Not calling you poor, just far cheaper than a tool post grinder.
Offline Pete12
« Reply #9 on: Jan 24, 2018, 20:40:03 »
Haha, no problem. As much as I'd like a tool post grinder it would be very hard to justify for the amount of times I'd use it.
