Author Topic: question for machinists  (Read 1584 times)
Online J-Rod10
    • Slipstream Cycle Works
Re: question for machinists
« Reply #20 on: Jan 31, 2018, 23:02:19 »
Coated, or uncoated?
Offline doc_rot
« Reply #21 on: Feb 01, 2018, 00:16:36 »
coated with a 1/2" boring bar. I was watching the tool deflect and just polish the inside.
Offline Pete12
« Reply #22 on: Feb 01, 2018, 04:25:40 »
Good result with the grinding doc.
Just had a look at that holder you tagged, never thought about cutting bolts down like it shows, great idea.
Offline crazypj
« Reply #23 on: Feb 02, 2018, 19:40:19 »
The problem I ran into is as the cut progresses the grinding stone wore down producing a slight taper in the bore. It was a little tricky but I got a pretty good fit.  If I was going to do this more frequently I would make something like this https://m.ebay.com/itm/The-ORIGINAL-Dremel-tool-holder-frame-metal-lathe-1-2-in-sq-shank-/361520655374?nav=SEARCH
Should have had a couple more stones on hand and just roughed out close to size first then changed stone to get better finish and parallel. It stones wore too fast due to depth of hole, just go so far ten finish with new stone.
It's real handy for 'parting off' tough / hard materials
Put a cheap 4"~4.5"Chinese diamond wheel on angle grinder to 'do' Titanium  or HSS  ;)
You only need a piece of heavy duty angle iron with some holes to hold angle grinder (and a bunch of washers / spacers to get it on centre)
« Last Edit: Feb 02, 2018, 19:45:14 by crazypj »
Best thing I ever overheard
Brian Morgan, 1982
