Author Topic: Project CB690 (KTM 690 engine in a CB550f frame)  (Read 12023 times)
Offline JustinLonghorn
Re: Project CB690 (KTM 690 engine in a CB550f frame)
« Reply #70 on: Jun 19, 2018, 08:42:21 »
Righteous work so far.
Into The Sunset, CB750 build
TT500 the Animal
Online Popeye SXM
  • Also used for MX
« Reply #71 on: Jun 19, 2018, 09:54:34 »
I like it. Moving the SA pivot forward and using the KTM SA is a good solution, keeps the pivot point close to the sprocket. I think the KTM SA looks great too
Offline goodoltup
    • Personal and Work Website
« Reply #72 on: Jul 08, 2018, 13:55:20 »
I took the forks apart in preparation for shortening. Minor panic as for a couple of days I thought that they could not be disassembled far enough to replace the topout spring, but after searching the internet for pictures I did notice that there was a hidden snap ring that allowed them to come apart. I will be ordering a spring kit that shortens the forks but maintains the correct spring rate. Also new seal kit, of course.
Offline goodoltup
« Reply #73 on: Jul 08, 2018, 14:00:58 »
Finished mocking up the tube and the motor mounts. The left motor mount is shaped so that it matches the shape of the stock sprocket cover. The right side one looks more like a simple triangle. The swingarm mounts will be made in 10mm plate, the front motor mounts in 6mm plate, all waterjet. The tube will be formed by a specialist mandrel bending company.
Also, I bought a cb550 tank. I like the gt550 tank better, but it would need tunnel modification in order for it to fit, and in order to keep this project running I thought it would be a good idea to minimise unknowns and potential problems as much as possible. I will keep the gt550 tank and maybe add it later for version 2.
Offline goodoltup
« Reply #74 on: Jul 08, 2018, 14:03:17 »
My manager gave me an engineering drawing of an automatic transmission. It has hand written notes and a date from 1968. I'm very thankful, it makes a nice addition to the garage.
Offline snowEH
« Reply #75 on: Jul 26, 2018, 17:46:51 »
awesome project cant wait to see more progress !
Sent from my SM-G935W8 using Tapatalk
Offline john83
« Reply #77 on: Aug 19, 2018, 22:30:54 »
Nice work! It's looking cool.
Offline Aussie Steve
  • As useful as an ashtray on a motorcycle!
« Reply #78 on: Aug 20, 2018, 12:36:12 »
Any exciting updates to share?
Sent from my Lenovo A6020a40 using DO THE TON mobile app
Bruce comes home from the pub and sees Sheila watching Gordon Ramsay's F%*#ing cooking show on the telly.
Bruce says; "What are you watching that shit for? You can't cook to save your life!."
To which Sheila replies; "So what? You watch porn movies, donít you?"
Offline goodoltup
« Reply #79 on: Aug 22, 2018, 17:23:03 »
Hi, yes, it's been too long since I've done any real work on the project. I wasted a lot of time getting the CAD files for the plates and tube, and wasted more time getting them quoted and ordered. I have now, however, received the plates from the water jet company. I ordered a few extra just in case I make a welding or grinding mistake. I sent the DXF files with a PDF drawing of the part with dimensions, but the water jet people just loaded the DXF and started cutting, not realising it was scaled 2:1. You can see in picture two that the front motor mount plates are huge, twice as big as they should be. The water jet people recut them and sent them out next day, so no harm done.
