Author Topic: 1981 GS750E (GSX750E) Rat Cafe Racer  (Read 5111 times)
Offline Aussie Steve
  • As useful as an ashtray on a motorcycle!
Re: 1981 GS750E (GSX750E) Rat Cafe Racer
« Reply #30 on: Aug 10, 2018, 03:43:46 »
Thanks!
Here are some photos of my 520 conversion. The rear sprocket is for a Suzuki DR 750 and the front sprocket is for various 90's Kawasakis. The chain is a very narrow d.i.d chain.
Front first. The sprocket has a section which is 2.6mm wider as shown here:
IMG_20180809_171020 by Lars Krogh-Stea, on Flickr
On the inside of the sprocket I have 6mm spacer similar to the one you see between the sprocket and the nut. The reason I have a spacer on the outside is because I'm missing the retainer washer. It's in the mail..  When I had it mounted like this the chain was to close to the rear tire. I flipped the front sprocket and put two 1.3mm washers behind the rear sprocket. Now there is 7mm clearance between chain and tire. I believe that is enough. I will at least try it for a while. With this configuration I can also use the original rear sprocket bolts.
IMG_20180809_172232 by Lars Krogh-Stea, on Flickr
IMG_20180809_172737 by Lars Krogh-Stea, on Flickr
IMG_20180809_172701 by Lars Krogh-Stea, on Flickr
Lookin' good, dude!
Sent from my Lenovo A6020a40 using DO THE TON mobile app
Bruce comes home from the pub and sees Sheila watching Gordon Ramsay's F%*#ing cooking show on the telly.
Bruce says; "What are you watching that shit for? You can't cook to save your life!."
To which Sheila replies; "So what? You watch porn movies, donít you?"
Offline LKS
« Reply #31 on: Aug 12, 2018, 15:48:30 »
Trying to get a little bit done each day..  today I dismantled the fork and painted them.
Fork by Lars Krogh-Stea, on Flickr
Offline LKS
« Reply #32 on: Aug 12, 2018, 17:45:48 »
And here it is with rubber booth installed.
Fork with booth by Lars Krogh-Stea, on Flickr
Offline LKS
« Reply #33 on: Aug 17, 2018, 17:56:07 »
Full by Lars Krogh-Stea, on Flickr
This bend and silencer came today. Almost a good match ;) I'll have to use some force to get them to fit..
 Inni by Lars Krogh-Stea, on Flickr
Mellomstykke by Lars Krogh-Stea, on Flickr
Extra by Lars Krogh-Stea, on Flickr
Have no idea what those two extra parts are.. Looks like a dbkiller but doesnt fit anywhere..  came with the silencer.
Offline MiniatureNinja
« Reply #34 on: Aug 17, 2018, 18:25:25 »
That thing looks pretty sexy!
'75 Honda CB360 - thread
Offline 1fasgsxr
« Reply #35 on: Aug 17, 2018, 23:13:57 »
Where did you source the bend. I need something like that.
Offline LKS
« Reply #37 on: Aug 18, 2018, 18:42:09 »
Tried to make the tube at the end a little wider by hammering a stepped tube inside it. This clipped two of te rivets holding the muffler together. I drilled out the last one and took it apart.
Clipped rivet by Lars Krogh-Stea, on Flickr
Stuffing by Lars Krogh-Stea, on Flickr
Hammered lightly on the inner ring to set the pieces together.
Separated by Lars Krogh-Stea, on Flickr
Put it back together with new pop rivets. From now I'll treat the two parts as one and mask off the bend before I powdercoat the muffler.
Back together by Lars Krogh-Stea, on Flickr
Offline LKS
« Reply #39 on: Aug 19, 2018, 14:54:16 »
Did the front wheel and brake discs in black :)
Front wherl by Lars Krogh-Stea, on Flickr
Disc by Lars Krogh-Stea, on Flickr
Rim painted by Lars Krogh-Stea, on Flickr
