Author Topic: Doing Research For Tracker Build Using Kawi Ninja 650 (Probably)  (Read 4369 times)
Offline canyoncarver
  • 'hacking is learning'
Ok I'm watching a kz750 right now it's a 1978 with spoked wheels and disc front and rear so I think I could lace up 19" rims to those hubs :)  Does anyone know if the geometry is the same for all the kz750 models, the one I'm looking at has a cruiser look to it?
I found this as inspiration for the kz!
Yes, later years for those were all Ltd style. 76-79 was a more standard geometry.  I dig these bikes.  That inspiration pic of the kz is stunning.
« Last Edit: Mar 22, 2018, 23:15:57 by canyoncarver »
73' The Commando
YZF750/1000R The Fly
KZ 750 Twin
ZRX 1100
KZ400 The Rabbit
KLR650, more Nortons, a BSA, my 93" shovelhead chop, an 86' FXR, and an F9 Bighorn
more YZF750R's, more KZ's, a Zephyr750...and the ever unfinished 75' CB550 cafe.
Offline johnu
small difference to the passenger pegs, and brackets over the years.
81+ have lower sub frame  top rails for the cruiser seat. I think the 76-79 were the "sportiest"  the biggest differences are
'76-'79  - 26.5 rake  105mm trail
'80 -        27 rake   110 trail
'81+  -      28.5 rake   112 trail
but those numbers also could have been manipulated by the wheel and fork changes they did so who knows.
Thanks!
You're right the frames could be the same, using longer forks would changed the numbers!
Offline johnu
So no luck with the bike I was looking at but I am going to try to find a 1978 kz750, I think it will be the best option.  I can use the stock hubs and lace 19's to them, the frame would need minimal mods to it also.  I would change the forks and shocks for sure, make my own pipes and foot controls.  Leave the engine stock for starters, this will be my boys first street bike (he has raced a lot of supermoto though).  I will source a tank and seat unit or make my own if needed.  Biggest hurdle is the weight....475lb :o  I would hope I can shave off at least 75lb and maybe more!
So now the search begins for a bike in California for less then $1500.
Offline doc_rot
Cool!  I am a fan of the kz750 because I like underdogs I guess and apparently these are really underrated motors because of a lame factory ignition and lean jetting from the factory which can both be rectified. I'm close to finishing mine can't wait to ride it.
« Last Edit: Mar 23, 2018, 21:46:13 by doc_rot »
Offline johnu
Link to your build please!
Wait for it...
73' The Commando
KZ 750 Twin
ZRX 1100
KZ400 The Rabbit
Offline doc_rot
lol, link to the build is in my signature below, Canyoncarver has a kz750 project of his own, link is in his sig.
« Last Edit: Mar 24, 2018, 04:25:13 by doc_rot »
Offline johnu
Offline crazypj
Thanks for all the help so far :)  I keep thinking about the wheels and I wonder if I could use MX hubs laced to 19" rims?  Only issue I see there is it would have to be single disc on the front.
You could probably bolt a Kawasaki MX rear wheel in, they have 19" rims stock (although rim is a bit narrow for tracker) There are tons of spoke wheel front hubs available, many from dual sport or 'adventure' bikes will have 'correct' diameter and width. May need to change bearings , custom spacers will almost certainly be needed whatever hub you use. If you find forks your going to use you can look at other manufacturers using same axle diameter/fork
I think the biggest bummer about the kz750 twin is the limited aftermarket support for the motors. There is some but not alot of options. No pistons.
 Bigger issue for any type of 'off road', KZ750 motor runs 'backwards'
It was designed that way to help prevent wheelies
They do have a lot of torque though, much more noticeable than an XS650
« Last Edit: Mar 24, 2018, 12:16:43 by crazypj »
Best thing I ever overheard
Brian Morgan, 1982
Offline doc_rot
Interesting. I knew the kz750 spun the opposite way,so do the kz400/440. I assumed this had to do with the counter balancer setup. Out of curiosity how would this prevent wheelies? With the crank spinning counter clockwise (when viewed from the right side) wouldn't that be more likely to bring the front end up? Why would that be bad for an off-road bike?
« Last Edit: Mar 24, 2018, 15:44:22 by doc_rot »
