Author Topic: Yamaha TW200.. the swamp donkey  (Read 10439 times)
Offline farmer92
« Reply #50 on: Jul 20, 2018, 22:34:14 »
I wouldn't be opposed to an xr/xl lump if I could find one cheap enough that doesn't need a bunch. Yamaha blaster motor has caught my eye too, if only because kiley hates two strokes lol
I was about to suggest a blaster engine
Like jimmerís little black blaster bike
Edit for link
http://www.dotheton.com/forum/index.php?topic=65541
Offline Hurco550
Re: Yamaha TW200.. the swamp donkey
« Reply #51 on: Jul 20, 2018, 22:36:32 »
I grew up riding a Yamaha blaster, they really are good little motors. I sure tried with no avail to destroy mine. Well actually I did grenade 3rd gear. Wish I had kept the lump around
~ bradj
Offline irk miller
« Reply #52 on: Jul 20, 2018, 22:41:18 »
My CB750 Chopper has a 1988 Blaster headlight.   ;)  Coincidence?
Offline Hurco550
« Reply #53 on: Jul 21, 2018, 13:48:07 »
Tw200 lump headed this way Monday, so I guess its back on the original schedule lol
~ bradj
Offline Hurco550
« Reply #54 on: Jul 23, 2018, 21:17:42 »
I had made up some quick alloy spacers for the front tank mounts just to get it in place, but wanted to use rubber ones for the finished design. Surprisingly, no-one makes off the shelf mounts to adapt an atc tank to a tw200 ;)
I found these "boat plugs" at the local Menards, and the o.d. and length of the rubber part turned out to be exactly right (score), just had to drill out the middle a bit, and Walla.
Also turned and welded in a threaded 10mm bung to mount the back, using rubber/ fabric washers top and bottom.
« Last Edit: Jul 23, 2018, 21:32:38 by Hurco550 »
~ bradj
Offline Hurco550
« Reply #55 on: Jul 23, 2018, 21:27:17 »
I spent the other part of the day going backwards on the project. When I was planning on putting in the predator engine, I cut a chunk of the down tube out to clear. Now that I'm putting a stock motor back in, I had to put it back. Glad my buddy hadn't hauled off scrap yet haha
I turned a slug on the lathe that fits the i.d. of the frame tube, then cut a ridge in it, which I used to line up the tube via the weld seam in the tube. Welded er up, ground er a bit and she's good as new.
~ bradj
Offline Hurco550
« Reply #56 on: Jul 26, 2018, 15:18:00 »
Missed the FedEx man with my engine this morning, so it'll likely be in tomorrow.
Here's a few pics of where I'm planning to go next.
One of the neat/ quirky things that has always drawn me too the tw's is the balloon rear tire which in stock form is mounted on a 14" x 4.5" rim. Tire options are a bit limited unless you go with an atv tire, which is what I planned to do. The kicker is that there are multiple cases of people either having to trim the beads or use upwards of 100psi to seat the beads on the tw rim, of which there are several reports of damage to the tire and injury.
The next "common" thing to do is to mount a 12" or 14" trailer rim to the rear hub, which is the route I plan to use. Those who have done it, tend to use the stock hub and weld a flange onto it. I am planning on making a hub from scratch, and at the same time, mount up a disk brake, caliper and hanger from a dr350.
The front wheel will likely get the same treatment, but with custom triple trees to widen everything out, as well as a set of xt350 forks and a disk brake.
These wheels are on the way and these are the tires im eyeing.
The red and white bike are what the bike will likely sit similar to, less the spoked wheels.
~ bradj
Offline irk miller
« Reply #57 on: Jul 26, 2018, 15:36:06 »
Man, I hope the same thing doesn't happen to your motor that happened to mine when I wasn't there to receive it the first attempt.  I swear they trashed the motor having to take it back and re-deliver it.
Also, have they tried the ratchet strap method to getting the tires on?  That's how I do all of my big tubeless tires like tractor tires and the trike tires.
Offline Hurco550
« Reply #58 on: Jul 26, 2018, 15:42:31 »
I am really hoping that it doesn't get destroyed too. At least it's insured but still it's a pain. That could be the case because I'm pretty sure it's like 80 lb.
I think they have used all manner of methods and Lubes and standing on your head with your eye cross crooked to try and get tires mounted. The take away from it is if you get a flat on the trail you are pretty much screwed on a change as the beads are really on there and terrible to get off.
~ bradj
Offline Hurco550
« Reply #59 on: Jul 26, 2018, 16:45:18 »
 plus, they still run a tube when they put it on the stock tw rim. I don't think it's a sealing issue, it's more that the bead is to tight.
~ bradj
