Author Topic: Yamaha TW200.. the swamp donkey  (Read 16890 times)
Offline Hurco550
Re: Yamaha TW200.. the swamp donkey
« Reply #20 on: May 16, 2018, 13:10:23 »
Ive been slacking a bit on updates, but I have still been tinkering around on this thing. I pulled the motor out and finally got the side cases (that a previous owner had graciously decided to use jb weld as "gasket material") pulled off, beit with a good amount of grunts, bloody knuckles and ez outs since ever single phillips head had been rounded off. What I found when I drained the oil was a highly undesirable paste of goo and metal shaving, along with a little more goo, and just when I thought I had found it all, more metal shavings.
Now, after a little bit of google-fu and some forum reading, ive found that these little tw lumps are notorious for shedding metal shavings, and there is a hippy esqe attitude in "the tw200 groups" of shavings are fine, just run it, but even so, there seemed to me an obnoxious amount of them. I figured no time like the present to dig in and see where they are coming from. I wasn't planning on splitting the cases, but I guess plans change. Upon removing the inspection cover for the cam chain, I had a "well theres your problem" moment. The engine was pretty obviously starved of oil at some point and the aluminum cam bushing had been eaten away.
To remedy this I will need source a roller bearing and a new cam. Its been done before and documented, so hopefully wont be to big of a deal.
Also, here is the expected pic of parts piling up for the build ;)
« Last Edit: May 16, 2018, 13:13:01 by Hurco550 »
~ bradj
Offline canyoncarver
  • 'hacking is learning'
« Reply #21 on: May 16, 2018, 17:05:22 »
That was a lot of metal in there. What's the parts scene like on these motors?
Offline irk miller
« Reply #22 on: May 16, 2018, 18:32:09 »
Just curious if you're to the point where this becomes a parts bike for another one, or if it's really worth rebuilding what you have.
Offline Brodie
  • Gold Coast, Queensland
« Reply #23 on: May 16, 2018, 18:56:51 »
I still say stick a bw350 engine in it...
Offline farmer92
« Reply #25 on: May 16, 2018, 19:10:59 »
I’d say he’s around the “at least it’s not more broken than when he started” point
Offline ridesolo
  • You only bear responsibility for your own actions
« Reply #26 on: May 16, 2018, 21:36:30 »
I knew you should have kept that XL650 lump!  Some silicone spray, a shoehorn, and a little time and you'd be riding.
“Fight on and fly on to the last drop of blood and the last drop of fuel, to the last beat of the heart.”
— Baron Manfred von Richthofen
Please check out:  http://www.VetTix.org
This is cooking away out in the shop:
'75 Honda CL378: http://www.dotheton.com/forum/index.php?topic=56547.0
This is an on-going Non-Motorcycle saga:  http://www.dotheton.com/forum/index.php?topic=71319.0
This one is FINALLY done: (!)
'70 Rupp Roadster: http://www.dotheton.com/forum/index.php?topic=67459.0
Offline cbrianroll
« Reply #27 on: May 16, 2018, 22:00:11 »
Doesn't their 250 motor fit it or parts compatible?  I thought my buddy mentioned something like that.
Offline Hurco550
« Reply #28 on: May 16, 2018, 23:25:18 »
Not sure I'm ready to give up yet. Entire engine swaps are pretty tricky due to the extreme offset on the countershaft sprocket. There is actually an outer carrier bearing that is part of the sprocket cover. Even a bw350 motor utilized a jack shaft on the swinger, so its not a real easy swap at that. Heads, however are a little easier to come by. I don't have the list handy, but a number of tt225 xt225 xt200 and a few others are direct swaps, and can be had complete with cams, valves and rockers for around $70 used.
That said, if I find a complete better tw200 for a reasonable price, this one will quickly become a parts mule.
~ bradj
Offline Brodie
« Reply #29 on: May 18, 2018, 16:39:37 »
That engine looks a hell of a lot like a sr250 so that might be an option as well.
