Author Topic: Nanno's "mule" a TR1 for everyday  (Read 5272 times)
Offline der_nanno
  • Faster!
    • Greasy Greg
Re: Nanno's "mule" a TR1 for everyday
« Reply #20 on: Jul 24, 2018, 03:13:11 »
After making some good progress on the engine earlier this week, there was one other thing that has been bugging me ever since I bought this bike. When I bought the bike I suspected that it had been in a crash at least at some point in its life. A few fork swaps and the fact that a rubber mallet was needed to install the upper frame in the lower frame mounts lead me to believe that the frame was buggered as well.
But before I could swan-dive into the frame swap, I decided that I had to tackled the heads first. Not very surprisingly I found a leaking valve cover. The reason it was leaking was due to a combination of really poorly executed thread repair or in other words: The threads were COMPLETELY on the proverbial p*ss.
Some fresh engine paint to make the heads look representable.
Well my crash-free XS1100 fork legs, I've been running the last few years have turned out to be not quite so crash-free, one of them suffering from approx. 4-5mm (1/4") of runout.
Next was trimming some no longer needed parts of the frame. I have a different breather setup than stock so that rear bit of pipe was no longer usefull to me.
The paint job was nothing to write home about, a coat of grey primer and then another one of satin black. I also painted the yokes, because they were looking a bit tatty and ever since I painted the lower one on the Turbo black I wanted to do the same on the mule. (Mind you a hot and humid 30 degree Celsius day is perfect for painting and even I can achieve some half respectable results!)
New steering stem bearings installed and frame and yokes are back in unison.
And that's the new frame installed and among many other things, the rear subframe bolts align correctly and the airfilter base isn't bent anymore... Fun-fact: This frame is so straight (compared to the old one) that to my huge surprise, the forklegs fell back out, whilst I turned round to pick up the allen wrench from the workbench. The old yokes required some serious twisting and turning AND a rubber mallet to get them in and out.
And some damage you find along the way:
I've had charging issues for a long time on this bike, with one of the main reasons being this plug. It's been well fried since... no idea. Cleaned the contacts and filled it with di-electric grease and it should be good until the new engine goes in, which has a good plug.
So you hear me going on, on just how badly bent the frame was, but then again, everybody can say that. See those brake pads? My old forks even required an extra washer to center the wheel in the forks.
Looks just like before (almost)...
... the old girl tracking straight is a nice bonus though.   8)
Blog-Post: http://greasygreg.blogspot.com/2018/07/the-new-tr1-engine-more-fixes-more.html
My Blog:
Offline doc_rot
« Reply #21 on: Jul 24, 2018, 05:11:19 »
nice work. did you straighten the legs? The old small diameter forks are surprisingly easy to bend. I watch a buddy straighten one simply by pushing on it with his body weight while it was in some v blocks.
Offline der_nanno
  • Faster!
    • Greasy Greg
« Reply #22 on: Jul 24, 2018, 05:18:30 »
No, I simply bolted on the ones that were in the turbo (for now) and ordered a new stanchion for the forks that were in there.
And yes, I've "corrected" fork legs in the past, but because this one was as bent as it was, it has damaged the chroming quite a bit, so I would have to send them out to get re-chromed. As such a good used one is the cheaper alternative.
« Last Edit: Jul 24, 2018, 05:28:17 by der_nanno »
My Blog:
Offline der_nanno
  • Faster!
    • Greasy Greg
« Reply #23 on: Jul 26, 2018, 10:30:52 »
... and she lives again.
(This is a video from the very first start earlier today...)
My Blog:
Offline der_nanno
  • Faster!
    • Greasy Greg
« Reply #24 on: Jul 29, 2018, 04:04:06 »
You all know how the story ends (with a working engine), but the steps in between might be interesting to some.
So first I installed the clutch.
and then there was the elephant in the room, aka the stripped threads of the valve adjuster covers. So I made some press-fit plugs...
... and glued on an old valve cover with superglue to act as a guide ... (Btw.: Superglue is indispensable in every half sensible machine shop. Once heated over approx 100 degree Celsius it will disintigrate or if that is not an option, a quick splash of Acetone will soften it up instantly.)
Drilled and tapped and we have a leak-free valve cover again. (As I wasn't as content as I make it sound now, I put this head on the front to have easy access in case it wouldn't work out...  ::) )
I went through my stash of cams and gear and picked a nice set that came together with a nice set of hardpad rockers.
Ball bearings are a must
Timed up (I am starting to become a huge fan of painting those adjustment marks
Even though the rockers came with only lightly worn adjusters, I opted for some swivel head adjusters as they protect the valve ends from getting gauged and as such result in much longer valve-adjustment intervalls. (Remember this is one of my daily drivers...)
And finally I stole a good plug off an old XV1100 alternator as the one on there was slightly cracked.
There's a blog-post that goes with all of this: http://greasygreg.blogspot.com/2018/07/the-new-tr1-engine-finishing-engine.html
« Last Edit: Jul 29, 2018, 06:19:35 by der_nanno »
My Blog:
Offline der_nanno
  • Faster!
    • Greasy Greg
« Reply #25 on: Jul 29, 2018, 06:07:47 »
I admit I'll keep this one a bit brief(-er), as some of the steps are rather well known by now.
Stripping the bike down to the frame was a quick and easy enough job to start with.
Taking the exhaust apart required a bit of gentle newtonian-persuasion or in other words a rubber mallet. There will be more on the Mk.7 exhaust further down this post.
Old engine out.
Seriously say what you will about chain enclosures, but if you 115,000km sprocket and chain looks like this...
This lower stud wasn't only a bit bent, but also the threads were pretty knackered. And once more it was one of those "special" M10x1.25 Japanese standard threads.
On paper the BT1100 inlet rubbers are the perfect tool for the job to fit VM38s or Dellorto 40iess, but the geometry of the retaining lip is different, so they don't sit right and more importantly don't seal very well.
And then there was this little thing: Ever since I built this very first Mk.7 exhaust, it bugged me, that the exhausts weren't level AND I couldn't find the fault. (I admittedly only had rather limited time to check...) It turned out that the downpipe of the left silencer was a bit too long and bottomed out in the joint causing the Y-pipe to shift and thus have both exhausts sit at different heights.
In the end this all turned into a one-and-a-half day marathon, because of all the small niggly bits that needed touching up - like this solenoid cover, when you use heavier gauge wires.
Talking of solenoids... this one shorted out BEAUTIFULLY. From now on, I will check continuity on every solenoid with a meter before installation, because in stock form one side will always have continuity, that's the side that goes to the starter.
Aaaand a bit of the good ol' 20W50 (mineralic) oil for running in. Cheap and cheerful and thick enough to protect the engine during those first km and especially hot weather (currently every day was over 35 degrees Celsius, which is over 100-something F)
... and the corresponding blog post: http://greasygreg.blogspot.com/2018/07/the-new-tr1-engine-installing-engine.html
That's it, now you're up to scratch. The next post will be about what happened during the very first break-in run and my experiences/verdict on the welded up heads and then (at least from an XV-perspective) I'll pick up work on the Turbo TR1 again...
My Blog:
Offline der_nanno
  • Faster!
    • Greasy Greg
« Reply #26 on: Aug 11, 2018, 05:04:18 »
Now with the first approx. 300-something kilometres (200 miles) done, it's time to look back a bit, report some of the mishaps and also ultimately evaluate whether all of this was actually worth it. (Hint for the impatient: Hell yeah.)
The first 30km of run-in were generally rather uneventful, it was a very hot day and due to the increased internal friction and some (admittedly) rather tight clearances the oil quickly got to 120 degrees celsius.
Interestingly enough, for some odd reason, the front cam cover just didn't want to seal properly, even though it was fine on the old motor and not even a new seal would cure it.
I also installed the wrong oil-pressure switch (a closer), which meant the warning light would light up instead of go out. The Volkswagen-part-number below will get you a blue 0.35bar opener, which is an acceptable substitute until I can get a switch for the correct range. It starts flickering at around 0.6bar, which is quite a bit lower than you'd want to go in terms of oil-pressure on such a crank.
... and then there was a little rideout with my dad, when spontaneously the rear plug decided to call it quits and I had to get some H*nd*-branded BP7ES plugs. Aside from that I could feel the engine starting to free up at around 100km on the clock and it became apparent that the old girl is actually quite a bit faster.
Because I didn't want to drill holes into the cylinder heads, I originally opted for BT1100 inlet rubbers. This sounds like a clever idea on paper, but it isn't as the retaining lip is a different shape and the carbs aren't held in very well. At this point I also started to tweak the carbs and installed #185 mains, instead of the #175s I had in there before. I also had to tweak the air-screw a bit and increase the idle speed as those welded up heads just flow A LOT more air.
As one forkleg of the originally installed XS1100 forks was a bit bent, a good used stanchion was acquired. This was also the moment to do the long overdue fork-oil-change on the other leg.
A little dab of molykote to decrease the break-away stiction.
The airfilter got a bit of cleaning and re-oiling as well.
And even the oilchange revealed no nasties.
The only leakage left at this point was the seal around the clutch actuator arm. Fortunately this is a generic industrial item with 14x25x5mm dimensions and a single lip seal and it sets you back a whopping 3 Euros at your local bearing shop.
Removal can be done in situ, you just have to screw the adjuster bolt all the way out, then you can insert a flatbladed screwdriver and just pry it out when the cases are hot. A bit of vaseline or petroleum jelly on the in- and outside of the new seal make installation a lot easier.
So what's the verdict, how does she go? Well, she goes like stink. Initially I worried that the bigger ports and valves would lead to losses down low in the rev-range, but there weren't. Objectively I would actually assume, that there's even the odd extra newton-meter/pound-foot happening, but as the whole engine now revs a more linearly you don't feel it as much. The biggest difference is from 4000 rpm onwards. The old girl now just SHIFTS. With the 750 heads you could feel that she was running out of breath somehwere around or shortly after 6000rpm and the last thousand rpm to the redline were only to be used as a buffer. Now she happily revs to 7500 and would probably even go a bit higher, if I hadn't set my limiter accordingly. I did notice that sucking through the frame is now definitely holding the engine back a bit.
On the whole I am very happy with how the engine turned out and she goes just as I would have hoped, I admit that it will be a couple more weeks until I am able to harvest the full potential of the engine, as I am still dialing in the carbs and with only approx. 300km on the clock there's quite a bit of freeing up going to happen.
Blog-Post: http://greasygreg.blogspot.com/2018/08/the-new-tr1-engine-first-200-miles-part.html
(More on the blog - as usual)
My Blog:
Offline Popeye SXM
  • Also used for MX
« Reply #27 on: Aug 11, 2018, 22:50:21 »
Impressive work. What do you think your compression is with the welded heads? I am planning a TR1 cafe race, already have the dona, and looking to wake up the motor a little. Did you get around to shortening the jugs?
Offline der_nanno
  • Faster!
    • Greasy Greg
« Reply #28 on: Aug 14, 2018, 11:14:11 »
Compression is a hair short of 10:1 (figuring in the inaccuracies of my measurements it is somewhere between 9.7:1 to 9.9:1)
Nope I didn't shorten the cylinders, it's not something that will actually increase the power notably, but it will improve squish and therefore efficiency.
If you want to liven it up, also consider a different exhaust and carbs. Those two made a hell of a difference even on an otherwise stock engine.
« Last Edit: Aug 14, 2018, 11:20:44 by der_nanno »
My Blog:
Offline Popeye SXM
  • Also used for MX
« Reply #29 on: Aug 14, 2018, 12:32:16 »
Quote
Thanks. I am considering fuel injection possibly with throttle bodies from a Ducati bandit. bigtwins.co is advertising performance cams which is also a maybe  :D
