Author Topic: Nanno's "mule" a TR1 for everyday  (Read 3444 times)
Offline der_nanno
  • Faster!
    • Greasy Greg
Re: Nanno's "mule" a TR1 for everyday
« Reply #30 on: Aug 14, 2018, 14:00:05 »
EFI might be nice, but be aware that running your ignition over MS is not gonna work without a 36-1 wheel driven by the cam. Hot cams... well, they might work, but all the racing guys in Germany (and there's quite a few really fast TR1s), don't have much good to say about the cams aside from the Megacycle ones. Especially as the stock valve springs are too hard and bind rather quickly, which means you have to buy the whole lot, if you want to enjoy your build a little longer.
My Blog:
Offline Brodie
  • Gold Coast, Queensland
« Reply #31 on: Aug 15, 2018, 12:48:01 »
Hey mate. Nominated your bike for bike of the month. Hope your cool with that.
Offline der_nanno
  • Faster!
    • Greasy Greg
« Reply #32 on: Aug 15, 2018, 18:33:44 »
Wow thx for the honours...*blush*
My Blog:
Offline der_nanno
  • Faster!
    • Greasy Greg
« Reply #33 on: Aug 18, 2018, 07:54:46 »
Sort of a somewhat final update. (for now and before I bore everyone to death with it) The engine has now covered roughly 1000km. I am pretty happy with what I've built. It really took until about 750 - 800km for the engine to really free up and start to unleash the full potential. I had to upjet next to everything from the old setting as the engine sucks in a lot more air. My VM38-9s are now set to:
Pilots: 17.5
needle: clip one lower than middle (richer)
Mains: 185
Airscrew: 2.5 turns out
Overall the engine revs happily to 7500rpm, yet still is driveable from 2500rpm onwards, even though I admit, that the old motor with 750 heads had more torque between 2500 and 3000. From then onwards they are on par and from 4000 onwards it's not even remotely comparable. Currently I end up being too fast by about 20 to 30kph wherever I go compared to the old engine. Oil-consumption, even during break-in was rather moderate, at around 300ml on 800km, which makes about 400ml on a thousand and I expect that to get better with the miles clocking up.
So my final verdict, are the welded up heads worth it: Well, yes and no. Yes they are definitely a nice way to make some extra power, but at the cost of shifting the power band up by 500-600rpm. Some more extensive porting might bring that figure down another 100 rpm or so, but that would require some very extensive work including building up the ports etc., which is way beyond scope for a nice lively daily ride. All in all considering the effort involved in making them, I don't think a production run is really viable, give the fact that overall response is non-existant in this forum. So if you're interested: I have one spare set, which I will sell and that's probably it for 2018.
My Blog:
Offline der_nanno
  • Faster!
    • Greasy Greg
« Reply #34 on: Sep 03, 2018, 15:57:37 »
... as if I were ever happy and content, with what I build.
TM38-85, first preliminary jetting tests, show rather promising results with #20 pilots and #180 mains.
My Blog:
Offline Brodie
« Reply #35 on: Sep 03, 2018, 16:38:14 »
Now for the fun stuff.
Offline der_nanno
  • Faster!
    • Greasy Greg
« Reply #36 on: Sep 20, 2018, 04:00:53 »
As you might have noticed, I am pretty fond of the TM38s, but the original choke location is annoying as hell. Luckily there's cable chokes.
Let's start off with a bit of "where's Waldo?" - no really there's a choke knob in this picture.
Rising to the occasion I also swapped out the inlet rubbers as the old ones were... old and from my parts bin, i.e. they were already old before they made it there. So there you go: inlet rubbers, 2in1 junction box, a few bowden-cable-ends and two new cable-chokes (M10-thread - thank me later, when you find out, why this info is important   8) )
The nipples are 6mm for the lever on the bars and 4mm for the chokes.
A few tips 'n' tricks, if you plan to replicate this: Rather make the cables a tad longer or you might encounter an over-rich condition when turning the bars. The other trick: always tin up the ends of the cables as well. I usually etch them with "soldering water" (sulphuric acid) and then tin them up the first 5mm (1/4"). Now GENTLY clamp the cables in a vise and adjust so the cable end sits slightly below the end of the nipple. This way the tin will be sucked in into the nipple and you have to do next to no cleanup afterwards.
... and with a tad too much tin, it'll look like this:
That's what it looks like now under the tank. I use an old ratchet strap to hold both junction boxes to my TCI, so they can't rub and stay nicely put.
If you did a half decent job with the cable lengths there should be no need to sync the choke cables, as they only know "full-throttle" anyway.
Blog: http://greasygreg.blogspot.com/2018/09/everyday-tr1-new-tm38-carbs-part-2.html
« Last Edit: Sep 20, 2018, 04:03:20 by der_nanno »
My Blog:
Offline der_nanno
  • Faster!
    • Greasy Greg
« Reply #37 on: Oct 02, 2018, 17:15:43 »
The welded up heads are giving me some grief, so I decided to overhaul the XV700 heads and convert to them on Thursday and subsequently find out what the h*ck is wrong with those heads as it's eating plugs whenever you give it a decent handful.  :-\
My Blog:
Offline der_nanno
  • Faster!
    • Greasy Greg
« Reply #38 on: Oct 10, 2018, 01:49:10 »
As you saw, I later then used XV1100 parts, if it's your first XV-engine build (or you don't have a fully equipped engine shop and have to pay for certain mods), go with older Virago stuff.
That being said, I have a second set of welded up heads and if you want, you can have them. Thing is, it'll be a while until I find the time to dig into them. I will very soon start a new engine for a certain someone on here and that will have to be done before digging into anything else. Also my dad wants me to dig into some of his bikes and get them up to a comparable standard as my old junk.
With that being said, let's get back to some more info on what happened (for those of you, who follow the blog, nothing new, sorry).
Those welded up heads are all about learning for me and of course, make heaps of power. As you can see in the pictures below, I've got some mad heat issues in the head and at the same time it acts as if it were running really rich. If you look closer at the piston, you will see by looking at the shape of the carbon deposits, that the swirl I wanted to create worked beautifully. (Tear-shaped residue on the piston.) It got a bit hotter than I like, but the clean sides on the pistons indicate that the combustion is centered nicely in the middle and there are no hotspots on the sides, which was my biggest worry with such a huge combustion chamber.
So the "mule" will now be set up like a good everyday engine should: very torque-oriented. But first a bit of damage on the XV700 heads had to be cured. One of the fins had broken off, when I had the heads shipped over from the US. Old grime and dirt was so deep into the pores of the ally casting, that it was an absolute nightmare to weld.
Bit of the old flapwheel action made it look representable enough for the underside of a cylinderhead.  :r:
... and some more prep-work like running a die over all the studs and a tap through all the threads.
And (of course) new valve stem seals and lapping in the valves.
From here onwards it was a pretty quick route down from this:
to this:
Unfortunately, good Gen1 cams with little wear on them don't exactly grow on trees or in other words, I only had exactly one set left and so I had to move them over from one set of heads to the other.
New heads on.
Just because you've done dozens of these things, doesn't mean you're not allowed to take a note on the inside of your engine cover. (Also it came out as a nice arty-farty-shot with the lights 'n' all  :bg: )
And then ultimately introducing you to the three-legged-throttle-cable-spider (cables being oiled with super-thin sawing machine oil) and even if you don't believe me: It makes one hell of a difference.
The new TM38-86 carbs finally being set up and ready for action.
... and installed:
One of the funniest things about the new engine that I only noticed yesteraday was, that for the first time in about 6 years, I now have an alternator, which works on all three phases. Now how's that funny? Well simple, I was so used to the charging system being insufficient, that I totally got used to riding around without lights or only on LED pilot lights, that when I did some measurements yesterday, I was a bit shocked to find out, that the bike now actually charges below 2000rpm just fine. (Not the worst of surprises to be honest - especially as my sidecar currently isn't charging at all...)
Blog: https://greasygreg.blogspot.com/2018/10/the-new-tr1-engine-learning-from.html
My Blog:
Offline der_nanno
  • Faster!
    • Greasy Greg
« Reply #39 on: Dec 26, 2018, 05:14:02 »
This is two posts in one:
The last bit of fine-tuning comes in the shape of having to get a different needle. Specifically one that is a bit richer than the one that is currently in, especially in the first 1/4 of the needle operation.
After quite a bit of research, I found the data for the following table containing the recommended needles for a Mikuni TM38:
As a result I ordered a set of 6FJ40ies, as the bike is running an oversized pilot jet at the moment. (Causes it to run really rich, when hot and give me sub-par gas-mileage.) Which I hope to cure with the richer needle. That being said, I also (sort of) created my magnum opus on how to jet carbs, determine the right needle and various other lesser issues. If that's the sort of thing you're into (and lots of reading), then please go ahead and have a look. Generally, if you guys want to have more info on how I go about tuning carbs poured into articles, let me know and I'll give it a shot - I've got some ideas on best practices, fault finding and others. Mainly because I've been chasing a few on the TR1 and my XS-Triple sidecar (which is also running on flatslides and gives me plenty of headache).
Blog-Post: https://greasygreg.blogspot.com/2018/12/carburettors-more-than-you-wanted-to.html
Just a quickie: This is the picture to go with the post above:
As you can see, thee 6FJ40 is a lot slimmer. It looks rather dry overhere, if I can get rid of the inlaws quickly enough, I might give the old girl a quick shakedown and see if this goes in the right direction.
Full blog-post here: https://greasygreg.blogspot.com/2018/12/more-carbwork-both-on-tr1-and-xs-triple.html
My Blog:
