Author Topic: Honda cb750 Cafe/Brat build  (Read 1453 times)
Offline The Limey
  • Evil English Villain
Re: Honda cb750 Cafe/Brat build
« Reply #10 on: May 04, 2018, 21:03:55 »
Looking gewd.  The trick with cradle frames is to lay the motor on its side and carefully lower the frame sideways over it.  Much easier to handle the frame around the motor than the motor into the frame.
Offline WhyNot
  • ~~~If it ain't raining, I'm riding~~{iii}?~~prost~
« Reply #12 on: May 05, 2018, 06:56:53 »
All I can say is......"wow"...................
2006 Harley Davidson Heritage Softail
1975 Honda CB750K5 needs carb work
1974 Honda CB350F2 needs tins painted (being lazy)
1972 Honda CB175K2 roller no engine
1972 Honda CB/CL350 Engines need roller
1972 Honda SL350K2 Frame for above engine
1972 Honda CB100K2 needs kicker shaft
1990 Mitsubishi MM needs engine rebuild
1984 Dodge D50 Beater DD since 1997
Offline Dodgerdaddy
« Reply #13 on: May 05, 2018, 15:17:50 »
Yes we put the motor on itís right side and the frame went on super easy, wrenched my back getting the pallet out of the pickup.
Offline Dodgerdaddy
« Reply #14 on: May 05, 2018, 20:12:36 »
Just picked up the wheels from Cycle Gear and the VHT rollbar paint still looks great, the guy who mounted the tires thought they had been powder coated.
Offline MiniatureNinja
« Reply #15 on: May 05, 2018, 21:57:10 »
awesome. you did the painting right? just the VHT to the raw metal right? looks amazing
'75 Honda CB360 - thread
Offline Dodgerdaddy
« Reply #16 on: May 06, 2018, 09:04:20 »
After sandblasting gave a thorough blasting with an air hose and put the VHT on direct. I did a small paint booth out of pvc and plastic with a cheap box fan in the wall. Used cheap furnace filters over fan and a few heat lamps. I put wire around the wheel where the rim strips go, which made it easy to roll the wheel between coats. I did have to fix a few areas that I had runs just waited about a week to cure then it was sandable and I resprayed the area. I found a thread that said put paint thinner on a cloth and when you could rub and area and no paint would come off on the cloth you can sand. Tried this on the inside of the rim.
Offline Dodgerdaddy
« Reply #17 on: Jun 03, 2018, 10:15:01 »
Got it running in they frame yesterday, now just waiting on the 530 front and rear sprockets to arrive, then I ride....!
« Last Edit: Jun 03, 2018, 10:16:51 by Dodgerdaddy »
Offline Dodgerdaddy
« Reply #18 on: Jun 03, 2018, 10:18:22 »
Here is a full side picture.
Offline yozzer74
« Reply #19 on: Jun 03, 2018, 15:02:42 »
She sounds  sweet well done
