Author Topic: will an XL350 rear rim work with a CB360 rear hub?  (Read 424 times)
Offline MiniatureNinja
« on: May 06, 2018, 00:06:14 »
I know the XL hub won't work because of the offset - so I wanted to know if anyone can tell me if the rear rim will have the correct spoke angles for the CB360 hub
'75 Honda CB360 - thread
Online irk miller
Re: will an XL350 rear rim work with a CB360 rear hub?
« Reply #1 on: May 06, 2018, 10:34:39 »
You'll be able to buy the spokes with the correct length angle from Buchanan's.
Offline buckypat283
« Reply #2 on: May 10, 2018, 19:33:40 »
The CB hub has a slightly bigger diameter and is a good deal narrower between the flanges than an XL hub. You'd probably be able to get them together but you might have some nasty bowing on the spoke angle.
Offline jpmobius
  • where does this go?
« Reply #3 on: May 10, 2018, 19:57:10 »
Probably the stock length CB spokes will be fine.  And like irk says, Buchanan's can supply them custom.  Also, probably the angles will be ok, as the hub diameters are not that far apart.  You will have to assemble the parts to know for sure.
Mobius
« Reply #4 on: May 10, 2018, 21:12:36 »
I'll just have to try and see what happens. I was given the wheel assembly and I'm interested in using just the aluminum rim for weight
Sent from my SM-G955U using DO THE TON mobile app
