Author Topic: Cb360 Reassembly Help  (Read 23333 times)
Offline cb360j
Re: Cb360 Reassembly Help
« Reply #100 on: Aug 13, 2018, 11:24:44 »
Got the retainer in Friday along with an entire extra clutch actuator with all the correct pieces, ebay seller was very kind to send all the bits.
Got it installed, and adjusted. The new springs from barnett make the clutch pull super heavy (compared to my cb550 clutch), for anyone looking for heavier springs.
The only negative side to that is now I have clutch pop. But at least that is a step in the right direction and can be sorted out with enough patience.
Does anyone have a perfect way to definitively adjust out clutch pop? Or will I just have to find that perfect middle point?
Offline crazypj
« Reply #101 on: Aug 13, 2018, 12:16:10 »
If you haven't been checking this thread (http://www.dotheton.com/forum/index.php?topic=72090.msg907172#msg907172) you should as it's ame problem your having. I've posted a lot of pictures to try and explain how things should be working
Best thing I ever overheard
Brian Morgan, 1982
Offline cb360j
« Reply #102 on: Aug 13, 2018, 12:19:20 »
Was literally just reading that thread.
Offline crazypj
« Reply #103 on: Aug 13, 2018, 12:29:06 »
LOL,  8)
Brian Morgan, 1982
Offline raptormeat
« Reply #104 on: Aug 14, 2018, 23:42:53 »
did you try my advice?
Minimal CB378 Brat
http://www.dotheton.com/forum/index.php?topic=53242.0
DTT Red, White, and/or Black 360 Club - We also discriminate!!
Sexy RD350 Cafe Thing
http://www.dotheton.com/forum/index.php?topic=55882.0
Offline crazypj
« Reply #105 on: Aug 14, 2018, 23:50:42 »
 Have 'cover' adjuster backed all the way off, set cable so pointer lines up, fit cover and adjust screw so lift mechanism contacts push-rod.I'm pretty sure that's how it was done during assembly  8)
Brian Morgan, 1982
Offline cb360j
« Reply #106 on: Aug 15, 2018, 15:56:17 »
raptormeat I actually did not try it. But I did get it to adjust properly so no more pop for me thankfully. Just took about 45 minutes of sitting and really focusing on it ha!
Pj that is pretty much exactly what I did, it helped visualize where the adjustment actually was.
I don't know if anyone has looked at the original picture of how I the bike is, but since the seat was so low profile, I elected to lower the back of the tank for the purpose of making lines flow a little better and because with the original tank mount it looked goofy showing.
So what I did was heat the flange where the rubber originally went and bent it 90 degrees down. Took a simple piece of flat stock and drilled two holes and threaded them, then drilled two holes in the tank flange that is now bent and I took two screws that go through them and screw into the new mount.
It was kind of a good idea at the time, but I want something a little cooler and maybe more simple. How do most of you mount your fuel tanks?
I was thinking of using a similar concept, making the flange slightly larger and using one of the quicklatch hoodpins for cars. Thoughts?
Here is the link for what I am talking about
https://www.quik-latch.com/black-anodized-mini-quik-latch.html
Offline yorkie350
  • If it runs ride it if it dont polish it & dream !
« Reply #107 on: Aug 21, 2018, 10:03:32 »
Hi bud sorry to steal ya thunder but just put yozzer74 gs550 up for BOTM cos I was able to post the pics hope ya vote too bud its a cool looking ride for sure hope I get to see it in the flesh not too many miles from me
Life's too short to go slow at anything !  unless your re-building ya ride !!
 cb350f '72 café racer
 cb550f '78 Hailwood race rep
Offline cb360j
« Reply #108 on: Aug 21, 2018, 10:11:18 »
No don't be sorry, I'm glad he got nominated!
Offline cb360j
« Reply #109 on: Sep 20, 2018, 12:37:30 »
Does anyone have any recommendations as to which shocks are best for the cb360? What length as well?
