Author Topic: KZ750E 1980  (Read 675 times)
Offline davidc
KZ750E 1980
« on: May 14, 2018, 07:54:20 »
Has anyone replaced the front brake master cylinder with a modern unit.
I've tried a Honda Hornet and a Yamaha MT09- none will work with the old Kawasaki calipers.
I've replaced the piston seals and dust seals on the calipers and in the meantime, I've fitted a master cylinder over haul kit to the old Kawa unit- the lever isn't great as there is corrosion in the master cylinder bore.
Is it possible that the modern calipers are more efficient and don't need as much fluid per stroke from the master cylinder?
Regards
David C
Offline hillsy
Re: KZ750E 1980
« Reply #1 on: May 15, 2018, 02:44:04 »
MC's come in different sizes - it will be stamped on your original MC what the size is. You need to match this with the new one.
I'm guessing the one's you've tried are too small.
Offline davidc
Re: KZ750E 1980
« Reply #2 on: May 15, 2018, 08:00:38 »
Thanks for that info.
Where would the size be marked?
Regards
Offline datadavid
Re: KZ750E 1980
« Reply #3 on: May 15, 2018, 13:04:15 »
Possible? Yes, pistons are much smaller, but usually there's more of them. You still need to pump much smaller volumes of fluid with modern brakes, look for a m/c for some six pot brakes.
Offline datadavid
Re: KZ750E 1980
« Reply #4 on: May 15, 2018, 13:05:23 »
Size is usually marked underneath the m/c. Possibly the stock item can be honed/reamed back to function.
Offline doc_rot
Re: KZ750E 1980
« Reply #5 on: May 15, 2018, 14:18:33 »
stock MC bore for this model is 5/8" (16mm). There are cheap Chinese aftermarket ones on ebay for $30-40 that work OK but not great, they  have a tendency to leak. A new Brembo MC is about $120. high quality and works great.
Offline davidc
Re: KZ750E 1980
« Reply #6 on: May 17, 2018, 08:10:10 »
Thanks, for info.
The Yamaha MT09 unit is a brembo, I didn't remove the piston to measure the bore- I would think that an MT09 would have multi-piston calipers.
The corrosion hole is beyond reaming- I would need a replacement MC, I think
I have it back to working 90% and may now live with it
