Author Topic: 1979 Chevy C10 Hellride  (Read 3818 times)
Offline JustinLonghorn
Re: 1979 Chevy C10 Hellride
« Reply #50 on: May 25, 2018, 11:06:58 »
About an inch higher in the front, and you're golden.
Into The Sunset, CB750 build
TT500 the Animal
Offline trek97
« Reply #51 on: May 25, 2018, 14:01:31 »
Changing front wheels and tires is no small expense.  I think it would look really good though.
Long as they clear fender.
Offline irk miller
« Reply #52 on: May 25, 2018, 14:13:30 »
$500 isn't a huge expense.  Another set of springs was almost half that.  I could probably fit 20s inside the wheel wells with the right width, backspacing and offset.  I have a cart saved with two AR Torq Thrust to match the current set- 16 x 8 with 4 inch back spacing and -11 offset.  235/60R16 BF Goodrich Advantage T/A Sport tires.  If the springs don't get me exactly where I want to be, then I'll pull the trigger on the cart.  At least a 16 will put the tire back up in the wheel well where I want it.  I don't think it looks right if the front is higher on the tire than the back, which is a condition more difficult to achieve with a 16 rear and 15 front.  The rake also pushes down on the front end more at park, and works the nose down more during braking.
Offline irk miller
« Reply #53 on: May 27, 2018, 10:58:27 »
I got that Eibach spring set installed. Itís amazing what  just an inch does.
Offline 1fasgsxr
« Reply #54 on: May 27, 2018, 14:28:25 »
Looks great man.
Offline Maritime
« Reply #55 on: May 27, 2018, 14:38:23 »
Yep. Rad.
Offline trek97
« Reply #56 on: May 27, 2018, 18:35:54 »
Thats what Rach says everytime.
Offline der_nanno
  • Faster!
    • Greasy Greg
« Reply #57 on: May 28, 2018, 03:32:13 »
That's what she said.  8)
Edit: Trek 97 beat me to it.
My Blog:
