Tilt switch on an old bike?
djsmiles
Hi, I'm looking to replace my kill switch with a tilt switch. Got a 75 Honda CL360. I've been looking online but can't find a universal tilt switch. Anyone out there know where I can find one and the best place to install it?
Tilt switch as in senses angle and shuts off over a certain angle?
It would be much better add the tip-over switch rather than replace the standard kill switch. Lots of manufacturers make a tip-over switch. Some of the guys on the ZRX forums use a Triumph switch as an add-on mod. Sorry, I don't have the part number.
So you can just ride straight in the garage and throw it on the floor instead of turning it off and parking it?
The reason I wanted to use a tilt switch is because I installed these switches: https://www.ebay.com/itm/222227388306?ul_noapp=true
Turns out the push button switch is always open and it's too small to handle the power going through it. The hole in the handlebars is too small to replace with the correct button.
After doing more research I think the smarter option would be to use a kill switch relay. Do y'all agree? If so, Is it a SPDT relay that I would need and does anyone have a wiring diagram for how this would work properly?
https://www.amazon.com/Absolute-Holder-RLS125-Automotive-SRS105/dp/B00C0SATHE/ref=sr_1_6?ie=UTF8&qid=1526639815&sr=8-6&keywords=spdt+relay
Is this diagram correct for my scenario?
Yep relay is the way to go.
If your kill switch is normally open, then you'll want to wire the coils to the Normally Closed pin on the relay. If memory serves 87A is NC so your diagram is backwards.
Take pin 30 straight to the battery via a suitable fuse. That way you also reduce voltage drop through all the stock wiring and OEM switch.
We also sell exactly what you're looking for: The relay and the wiring together along with an inline fuse set up to feed directly from the battery.
http://www.sparckmoto.com/Products
Scroll down toward the bottom of the list and you're looking for the Ignition Coil or Headlight Subharness. $30 with free shipping in the USA.
