Author Topic: CB 360 no label parts build!  (Read 4597 times)
Offline Stayrad
Re: CB 360 no label parts build!
« Reply #10 on: May 29, 2018, 12:11:24 »
Okay it just is a little crooked. Iíll work on it tonight. Keep in mind I have basic tools. Iím just heating this up with a small propane torch and a vice.
Offline Stayrad
« Reply #11 on: May 30, 2018, 01:41:35 »
Look at these fresh valves! 🍻. Mmm
Offline Stayrad
« Reply #12 on: May 31, 2018, 01:36:38 »
Cheers to making it happen with the tools in your garage. Couldnt find a decent price on powder coating so I opted to use my paint sprayer black with a two part clear coat
Offline Stayrad
« Reply #13 on: May 31, 2018, 01:41:33 »
This was my first time trying this technique. I love it! Little blurry in spots but overall just cool.
Offline Stayrad
« Reply #14 on: May 31, 2018, 01:46:31 »
I love this clear coat. So easy to use.
« Last Edit: May 31, 2018, 02:01:12 by Stayrad »
Offline irk miller
« Reply #15 on: May 31, 2018, 09:03:59 »
The lace needs to be tight against the surface you're spraying too.  If you didn't cut out a hole for the fuel filler, then that's why it's blurry in places on top of the tank.  You can lightly spray a fixative to the backside of the lace, so that it's really tight to the metal, then spray.  They make fixatives that don't transfer to the metal, but any residual fixative that did stick to metal surface can then be cleaned off when the paint is cured.
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #16 on: May 31, 2018, 09:14:23 »
Tank looks great. I actually like that some spots are blurry, it breaks the pattern up a bit.
'78 Honda z50 - http://www.dotheton.com/forum/index.php?topic=76059.0
Offline Stayrad
« Reply #17 on: May 31, 2018, 09:24:16 »
Good call on the fixative. I did cut a hole for the fuel filler but the struggle was getting all of the angles without overlapping the lace. I was looking at tons online and it seemed like most people were doing relatively flat surfaces. Then filling in the curves with a solid color.
Definitely a learning curve.
The hardest part was hanging out in the lace section at Joanns fabrics with all the home school moms
Offline JustinLonghorn
« Reply #18 on: May 31, 2018, 09:50:03 »
I'm on board.
Into The Sunset, CB750 build
TT500 the Animal
Offline irk miller
« Reply #19 on: May 31, 2018, 10:08:05 »
Yeah, it's a cool technique.  I don't do it a lot with paint, but I'm a ceramicist, so I do it for glaze application.
