Author Topic: Honda CB750K Cafe Racer project about to start with a monoshock??  (Read 6721 times)
Offline rohalloran
Ordered a set of KZ1000 Police wheels today off eBay so hope to be able to update if these fit next week. They did not have brake discs fitted which was annoying so need to source some once I fit the wheels to see how the brakes will line up and what mods will be needed.
Also ordered some nice Spark End Cans similar to the ones fitted to this http://www.bikeexif.com/win-custom-motorcycle-ironwood-cb750.
Offline rohalloran
KZ1000 Police wheels arrived over the weekend. Almost smooth sailing with the fitment this evening.
Front wheel - Wheel bearings were the right size. Just need to take a few millimeters off the spacer.
Rear wheel - Wheel bearings need to be changed but all looks to align just fine. Have ordered a cush drive and rear sprocket carrier as they were not included with the wheels and the GPZ900 were different. Will report on these when they arrive.
I have to order front and rear disc brakes next. I can get the rear fine as I have found a disc that has a 130mm ID and 260mm OD with 7 bolt holes and no offset. (the GPZ900 disc was 6 bolt holes...) The front is a different story. The ID is 168mm and OD is 300mm for these particular wheels. The OD on the GPZ however was 280mm so I need to figure out how to accommodate for this extra 10mm of disc which will allow me to use the exitinging forks and callipers (they look quite chunky)
Thoughts are welcome on this predicament. (See thread for this here for some members ideas http://www.dotheton.com/forum/index.php?topic=75756.10)
Tried on one of the Sparks exhaust cans too which also arrived  8)
Offline doc_rot
dunno how crazy you want to get but this is an idea i have played with for a while. You can buy rotor blanks and have them water jet cut into whatever design you want.
« Last Edit: Aug 05, 2018, 06:26:53 by doc_rot »
Offline rohalloran
It had crossed my mind but I think I will just go with normal drilled pattern. Won't date.
Offline rohalloran
Been a while since I posted but there has been lots of progress with the build.
New piston kit arrived
Barrels rebored
KZ1000P front-end fitted
KZ1000P rotors arrived
Engine casing send to be soda blasted
All new bearings, gaskets and seals ordered for the engine rebuild
Here are some photos of the KZ1000P front end fitted
Offline doc_rot
Those disks are very nice, and they don't have the wonky a-symetrical drill pattern of the OEM disks
Offline rohalloran
They are from https://www.metalgear-shop.de/ Very reasonable price too.
Offline rohalloran
Shims arrived on Friday for the front calliper spacing / alignment.
Engine cases ready to go to be blasted..
All new wheel bearings and seals ordered
Offline rohalloran
It's been awhile since my last post but the build build is taking shape nicely. I have the engine almost rebuilt, tank ready to the paint shop, seat ordered from Tuffside and frame being prepped for the rear loop and powdercoating. Will get some photos up this week.
