Author Topic: Another T500  (Read 2569 times)
Offline farmer92
Re: Another T500
« Reply #30 on: Sep 03, 2018, 21:44:53 »
So now that i’ve got the electrical bs sorted, i need to track down which oil line is leaking 2t oil onto the top of the cases.
It looks to be coming from the pump side of things. Does anyone have a good source for plastic washers and m6 banjo bolts?
Offline farmer92
Re: Another T500
« Reply #31 on: Oct 02, 2018, 12:11:55 »
Manage to track down the oil leak, the line feeding the pump had a crack where it meets the banjo.
Thank goodness for spares!
Bike is running like a top.
Went to have it inspected, was told it needs a kill switch to pass despite not having had one from the factory. Thanks Quebec...
How would one wire a kill switch to the points ignition? Ground out both of the points i guess?
Online Hurco550
Re: Another T500
« Reply #32 on: Oct 02, 2018, 12:59:09 »
I ran stat-o-seals when I restored my gt250. a little pricey, but they work a treat. I ordered mine from mc master carr, but there may be a better/cheaper source for them up in canadia..
https://www.mcmaster.com/stat-o-seal-washers
~ bradj
Offline farmer92
Re: Another T500
« Reply #33 on: Oct 05, 2018, 07:34:10 »
Those look pretty nifty, i’ll have to check if anything is available up here, but not likely.
I just bought some nylon washers and they sealed up alright. Do you know somewhere that would sell the bolts and/or banjos?
Fitted up some fresh rubber on the front, nothing fancy.
Offline pidjones
Re: Another T500
« Reply #34 on: Oct 05, 2018, 08:15:57 »
Since it isn't for brake fluid, seems the bolt would be easy to make by center and cross-drilling.
Online Hurco550
Re: Another T500
« Reply #35 on: Oct 05, 2018, 12:10:29 »
Mc Master Carr has those too:
https://www.mcmaster.com/banjo-bolts
~ bradj
Offline Sonreir
  • Moderator
  • Oregon
Re: Another T500
« Reply #36 on: Oct 05, 2018, 12:49:21 »
I'm in on this one. Not sure how I missed it before.
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Offline Sonreir
  • Moderator
  • Oregon
Re: Another T500
« Reply #37 on: Oct 05, 2018, 12:51:45 »
That will work, but the preferred (and I think easier) method would be to place a switch in between the orange wire that feeds power to the ignition coils.
So cut the orange wire and put a switch in between the two cuts. You'll probably want to run some extra wire up to the handlebars or something similar.
Offline farmer92
Re: Another T500
« Reply #38 on: Oct 05, 2018, 13:56:31 »
Yeah I figured that would be the easiest but I wasn’t sure about having the current flow through the switch at all times
Offline Sonreir
  • Moderator
  • Oregon
Re: Another T500
« Reply #39 on: Oct 05, 2018, 14:06:22 »
As long as the switch is rated for the current, it won't be a problem. It's how most manufacturers do it.
If you have two ignition coils, each at five Ohms, we're looking at 3A per coil, 6A total.
The other option is to use a really small switch and a relay, but that starts getting a bit more complicated.
