Author Topic: Another T500  (Read 3850 times)
Offline Hurco550
Re: Another T500
« Reply #40 on: Oct 05, 2018, 14:19:13 »
This ought to be heavy enough ;)
"If you want safety and sanity don't mess around with choppers to begin with and don't come crying to me for recommending something that broke down the line. You're going to be the "builder" so use your own judgment and build to you own personal levels of safety and sanity." - Chopper Handbook
Offline teazer
Re: Another T500
« Reply #41 on: Oct 05, 2018, 19:32:46 »
As long as the switch is rated for the current, it won't be a problem. It's how most manufacturers do it.
If you have two ignition coils, each at five Ohms, we're looking at 3A per coil, 6A total.
The other option is to use a really small switch and a relay, but that starts getting a bit more complicated.
Much better idea. If you ground the points the fuse will blow.  You have to interrupt power to the points or to the coils.  Try to cut into the orange from the main switch to the coils and insert a relay in the circuit along with a simple switch.  You could also look for a GT750 72-72 right switch and throttle housing but they have a button for the starter which you don't need.  Maybe just a cheap pit bike kill switch.
Offline farmer92
Re: Another T500
« Reply #42 on: Oct 05, 2018, 19:51:33 »
Thanks
I think iíll set up a relay inline with the main fuse and look for a decent looking kill switch.
I donít mind the pit bike KS on something more modified, but it will look out of place on this bike.
Offline Brodie
  • Gold Coast, Queensland
Re: Another T500
« Reply #43 on: Oct 07, 2018, 02:55:56 »
Not sure on the oil banjo bolts on the T but I know my old TS had a check valve in the oiler banjos. Just something to consider.
Offline farmer92
Re: Another T500
« Reply #44 on: Oct 07, 2018, 08:41:08 »
That is correct, although i wonder of the importance of having the check valve in the banjo vs an inch away in the oil line.
