DIY...Walnut motorcycle service bench
Re: Walnut service bench
pidjones said:
Some day it will have oil stains and gouges - then it will be beautiful!
;D ;D
Speaking of which, how are you going to seal it? Spray on Poly?
Stain it with motor oil. Seriously. Look up using old/used motor oil as a wood stain. It's cheap, looks good, and works a treat too.
I plan to use up my left overs from the other projects I have done.
Sonics, super secret recipe...Dark Tung oil https://www.walnutwoodworks.com https://www.facebook.com/WalnutWoodWorks/
And I will add wipe on poly finish.
I used it on both the walnut workmate top and cabinet I made.
Nice. I like the wipe on poly. I used 7 or 8 coats on my coffee table. Its quite a bit of work.
Finished cleaning glue and sanding the bottom. Amazing how much faster that goes than doing the top. ;)
80 grit done topside. Next 120 and 220. Ugh.
Even added some fancy edges to it. ;D.
(hard to see unfinished, had to adjust contrast a bit.)
As cool as it would be and as much as I would like too do it.
I think Im gonna have to pass on checkering the top. It would just take too much time.
So I think I will just score a path w the circular saw. 1/8" deep cuts.
Came out pretty darn good. A spray adhesive and pneumatic stapler were key. Thanks bud!
Heck yeah bro, they won’t even see the seat. For your awesome glass and paint work. 8)
top scored.
Almost forgot the dowels. I think 18 per side w 5 on the end cap.
That Gorilla glue is great for this. The dowels were a TIGHT fit and even still just a smidge still cam bubbling up to the top.
Started at 4 a.m with an hour break for lunch and a cat nap. :p
80 -150-220 Sanding done, fit the hardware, dis-assembled for tung oil.
I haven't decided if its getting poly or carnauba wax finish.
The pic looks a bit splotchy right now, as the oil is soaking in and drying.
irk miller said:
So, will my chopper fit on it?
Possibly, 50" from front axel to rear of engine or center stand is max I would put on it.
Loading it alone...It may hold something a bit longer but I wouldn't chance it.
As long as the engine is "mostly" forward of the pivot, it could work.
With a buddy to help hold the front from tipping back, until situated and locked down. Yes definitley longer.
Re: Walnut service bench, all done but the finishing.
All done but the finishing...castors, tire chock...should be here Wednesday. Thanks Irc for your great ideas. 8)
Along w a small safety prop under the ramp end.
After some reading, Ill do another few coats of oil.
In a couple weeks Tung oil will cure hard. I can then buff it and apply Shellac or just leave it as is.
Very nice!
doc_rot said:
Very nice!
Thanks bud, the construction is rock solid.
The router-ing is definitley amateur hour. ;D
Rach bought me that router like 15 years ago, and this was its first time out of the box. ::)
But its the imperfections that makes up its charms....right?
