Author Topic: DIY...Walnut motorcycle service bench  (Read 6616 times)
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
Re: Walnut service bench
« Reply #80 on: Jul 12, 2018, 10:56:57 »
Some day it will have oil stains and gouges - then it will be beautiful!
 ;D ;D
Speaking of which, how are you going to seal it? Spray on Poly?
'78 Honda z50 - http://www.dotheton.com/forum/index.php?topic=76059.0
Offline JustinLonghorn
« Reply #81 on: Jul 12, 2018, 11:25:54 »
Stain it with motor oil. Seriously. Look up using old/used motor oil as a wood stain. It's cheap, looks good, and works a treat too.
« Last Edit: Jul 12, 2018, 11:28:55 by JustinLonghorn »
Into The Sunset, CB750 build
TT500 the Animal
Offline trek97
« Reply #82 on: Jul 12, 2018, 17:49:49 »
I plan to use up my left overs from the other projects I have done.
Sonics, super secret recipe...Dark Tung oil  https://www.walnutwoodworks.com   https://www.facebook.com/WalnutWoodWorks/
And I will add wipe on poly finish.
I used it on both the walnut workmate top and cabinet I made.
« Last Edit: Jul 12, 2018, 17:58:41 by trek97 »
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #83 on: Jul 12, 2018, 18:25:12 »
Nice. I like the wipe on poly. I used 7 or 8 coats on my coffee table. Its quite a bit of work.
Offline trek97
« Reply #84 on: Jul 12, 2018, 21:52:43 »
Finished cleaning glue and sanding the bottom.  Amazing how much faster that goes than doing the top.   ;)
80 grit done topside.  Next 120 and 220.  Ugh.
Even added some fancy edges to it.   ;D.
(hard to see unfinished, had to adjust contrast a bit.)
Offline trek97
« Reply #85 on: Jul 12, 2018, 22:03:19 »
As cool as it would be and as much as I would like too do it.
I think Im gonna have to pass on checkering the top.  It would just take too much time.
So I think I will just score a path w the circular saw.  1/8" deep cuts.
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #86 on: Jul 13, 2018, 09:25:29 »
Came out pretty darn good. A spray adhesive and pneumatic stapler were key. Thanks bud!
« Last Edit: Jul 13, 2018, 09:53:50 by advCo »
Offline trek97
« Reply #87 on: Jul 13, 2018, 10:02:15 »
Heck yeah bro,  they won’t even see the seat.  For your awesome glass and paint work.   8)
Offline trek97
« Reply #88 on: Jul 13, 2018, 22:17:01 »
top scored.
Almost forgot the dowels.  I think 18 per side w 5 on the end cap.
That Gorilla glue is great for this.  The dowels were a TIGHT fit and even still just a smidge still cam bubbling up to the top.
« Last Edit: Jul 13, 2018, 22:19:57 by trek97 »
Offline trek97
« Reply #89 on: Jul 15, 2018, 00:22:31 »
Started at 4 a.m with an hour break for lunch and a cat nap.    :P
80 -150-220 Sanding done, fit the hardware, dis-assembled for tung oil.
I haven't decided if its getting poly or carnauba wax finish.
The pic looks a bit splotchy right now, as the oil is soaking in and drying.
« Last Edit: Jul 15, 2018, 00:27:32 by trek97 »
