Author Topic: Cb360 timing omg help.  (Read 785 times)
Online irk miller
Re: Cb360 timing omg help.
« Reply #10 on: Jun 17, 2018, 14:07:46 »
Brenden at CMC has a good video for this.  He downplays the importance of gap, which I don't agree with, but otherwise it's right on target.
Offline MiniatureNinja
« Reply #11 on: Jun 17, 2018, 15:38:35 »
that's the video I tried to follow yesterday - he says not to even touch the backplate and totally ignore the points gap.
'75 Honda CB360 - thread
Offline jpmobius
  • where does this go?
« Reply #12 on: Jun 17, 2018, 15:41:44 »
There is a lot of good material in the CMC video, and there is no doubt that the procedure detailed will result in correctly set timing.  However, this is NOT a good procedure because, as noted it does not consider the point gap, and therefore the dwell to be of any importance.  It is absolutely true that nearly all points ignitions will indeed run with dwell angles wildly outside the specified range so long as the timing is reasonably close.  However, just because one person considers it to be unimportant, that in no way makes it so.  As I previously stated, maintaining the correct point gap is indeed very important - more or less so depending on a variety of factors, but important nonetheless.  For each revolution of the ignition cam, the ignition coil is energized for a percentage of that rotation.  That would be the percentage of rotation that the test light is off.  During this time, when the coil is energized, considerable heat is built up in the ignition coil.  When the light is on, the power to the coil is cut, and the coil is able to cool off.  Heat is the number one enemy of your ignition coils, so that cool off period during each full cycle of the cylinder is important.  The opposite, having too long a cool down period in theory could result in insufficient "charge time" in the coil, but in general this is not usually a concern.
Set the point gap first.  It matters not at all where the timing plate is or where the crank is positioned so long as the rubbing block for the point set you are adjusting is sitting on the highest point of the cam.  Set the timing after both sets of points are properly adjusted.  Your Honda has a single timing plate to which both sets of points are mounted, so in theory, adjusting it for correct timing on one cylinder will result in the other cylinder being correct also.  In practice however, the combination of the precision of all the various parts along with one's precision to set both sets of points to exactly the same gap usually results in very slight variance between the cylinders, so after setting the timing on one cylinder with the timing plate adjustment, you may have to correct the other cylinder timing by adjusting the points adjusting plate for that cylinder.  This is exactly the procedure outlined in the graciously provided manual pages in the previous post.  The info provided there is clear and exactly correct - follow it and your timing will be perfect.
Mobius
Offline jpmobius
« Reply #13 on: Jun 17, 2018, 15:52:52 »
ok so this is another example of CMC misleading people.
gonna have to do this right now. LOL
so use the 4 small screws to adjust the gap, and then use the base plate to adjust the timing. right?
I think it is in fact a bit misleading, but in truth, the point gap is likely to be reasonably close which is probably why he gets (I assume) good results.  It is a result of the fairly limited adjustment range when all the parts are new and properly assembled.  And, the performance requirement is fairly easy - compare to a V-8 car engine with a single set of points - It may redline at half the revs, but has to fire 8 times as often!
And yes, adjust the gap(s), then the timing for both cylinders with the single timing plate.  And as noted in the manual, you can go the extra mile by adjusting the other set of points afterwards to get that cylinder perfect as well if needed.
If you have a strobe light, it is easier, and often more accurate (depending on your static timing setting skills).
« Last Edit: Jun 17, 2018, 15:54:40 by jpmobius »
Mobius
Online irk miller
« Reply #14 on: Jun 17, 2018, 16:32:17 »
If you go by the manual pages (that's from the FSM) to the letter, and set the gap to .014 (like PJ noted), you will be very happy with the results.  .014 is right in the middle and the perfect gap for this bike. I'm pretty sure .014 is the typical gap for most points based bikes, but don't quote me on that.
« Reply #15 on: Jun 17, 2018, 16:56:10 »
ok thanks.
I was very frustrated and trying to shortcut - because I spent way too long trying to time it with the advancer in backwards before I realized what was going on. I feel pretty dumb but I am chalking it up to sleep deprivation and not having eaten anything that day... I really wanted to finish the bike
found that I am leaking brake fluid too out of the brake pipe which has been used and re-used too many times I guess
Offline crazypj
« Reply #16 on: Jun 18, 2018, 11:32:57 »
The backplate isn't a very good fit in housing so timing and gap tends to vary as timing is adjusted which is very frustrating. It is important to have gap between 0.012" and 0.016". Not adjusting backplate makes it almost impossible to get both sets of points in spec. I had an idea you didn't set gap at high point, seen it happen a lot. Often gap is set at 'F' mark so points never close. Have you downloaded The Hionda Common manual? (fills in the gaps in factory service manuals)
Best thing I ever overheard
Brian Morgan, 1982
« Reply #17 on: Jun 18, 2018, 17:12:01 »
I have that downloaded (I think its the one you linked in a thread)
I didn't set the gap properly, 2 timing videos said it wasn't important and I've had 1 points car ('64 VW bettle) and i don't think I ever adjusted the gap or timing in that thing the entire 8 years I owned it.
Offline crazypj
« Reply #18 on: Jun 19, 2018, 11:17:00 »
LOL, 'everyone' has had a Beetle at some time. I still have a 1970 one in a shed in Britain
Brian Morgan, 1982
