Author Topic: Xl250 parked for 30 years  (Read 1233 times)
Offline schonc
« on: Jun 16, 2018, 23:40:46 »
I'm a new member here on DTT. I joined to look at ideas for this build. Here's a few photos to start. I'll fill in the back story with a few follow up posts.
Sent from my SM-G930W8 using Tapatalk
Online irk miller
Re: Xl250 parked for 30 years
« Reply #1 on: Jun 16, 2018, 23:54:38 »
I love XL250s.  Looks in good nick outside of the dents.  I make those clutch adjustor plugs that fit into the left side case, so let me know if you need one.
Offline schonc
« Reply #2 on: Jun 17, 2018, 13:46:47 »
I was thinking I'd 3d print a new plug and put an o-ring on it but wasn't sure how well abs would hold up. I think I'll give it a try just as an experiment. I'll likely be ordering a plug from you shortly after haha
One thing I've been trying to find is a shop manual. Is there any chance one is floating around on the net in pdf form?
Now for some background I was promising
This bike is/was my father's first bike. It was used to drive cattle to/from the farm to the pasture in the spring/fall. From what I gathered from the disassembly, he and his buddies trashed it pretty good too haha.
The bike developed a "timing issue" and dad upgraded to an 87ish xl250r. The bike has sat in a storage building on the farm since.
The reason for the disassembly was that the farm is about a 13 hr drive away from where I now live. My original plan was to drive out there with the 95 f150 but quick fuel mileage calculations had this free bike costing a couple grand in fuel. (The old 351w is a great block but is lacking some efficiency)
The vw golf on the other hand is much nicer for road trips and better on fuel... just lacking a bit in storage vs the Ford... A princess auto (Canadian harbor Freight) roof basket solved that problem.
Anyways... back to the bike.
The obvious thing from the photos is the tank dents... which are numerous and I doubt will ever be removed. On the plus side, there is surprisingly little rust in the tank. A few spots of surface rust but mostly bare shiny metal.
The engine spins over very nicely and valve seem to just need a tune up. I haven't got the side covers off yet... I'll post photos when I do.
The wheels are a nice surprise. Damn near perfect shape. A clean up and maybe some spoke adjustments.
The exhaust from the headerpipe back is done. The first can was still on the bike but rusted and poorly repaired (and packed with acorns)
There's a few other small items I've noticed but we'll get to that in time.
My build plan is to get this thing up and running. I'd like to ride it a bit and then see where I'd like to take it from there.
Two things I'm considering are
1 Big bore/hp upgrades.
2 give it a more tracker look while maintaining its functionality.
I'd like to use the bike around the city (Calgary) and be able to take it on the highway for short distances to access some trails/dirt.
I've still haven't got the whole bike unloaded from the car. I'll post more photos with the unpacking and assessing what needs attention.
Online irk miller
« Reply #3 on: Jun 17, 2018, 13:51:55 »
Awesome.  Lucky thing on those side covers.  They are like hen's teeth and will cost you no less than $50 each to replace if you're lucky.   When you make the the plug, be sure to put an angle on the head.  You may have noticed, but just in case you didn't I thought I'd mention.  The case cover has angle to it as it orients to the plug hole.
Offline CCRider
« Reply #4 on: Jun 17, 2018, 20:12:32 »
Looks familiar.
Here's the link to mine http://www.dotheton.com/forum/index.php?topic=62808.0
Fun bikes.
Offline schonc
« Reply #5 on: Jun 19, 2018, 00:24:16 »
Looks familiar.
Fun bikes.
Yeah I was checking it out... want to trade tanks? Haha
Offline schonc
« Reply #6 on: Jun 19, 2018, 00:45:01 »
Had a hour to put towards the engine. Good news... Got the side cover off and it was pretty packed with gunk that came in from the adjuster hole but only minor corrosion on the front outside of the case.
While I was there I noticed that the sprocket cover had a bolt hole busted off. Should still do the trick but I'll keep an eye out for a new one.
Unpacked some more parts and got the forks out. Noticed this damage while disassembling but didn't have a chance to take a photo. Not sure of the cause but the other side has similar wear. They definitely won't keep a seal in that shape. Anyone have any suggestions on repairing?
Online irk miller
« Reply #7 on: Jun 19, 2018, 01:03:50 »
Those forks look like they may be bent.  Check and see.  It's an easy fix, if you have a press and a vee block.
Offline schonc
« Reply #8 on: Jun 19, 2018, 01:12:12 »
Ah yes, makes sense. I'll check them out next time. Thanks for the help irk!
Offline CCRider
« Reply #9 on: Jun 19, 2018, 08:04:20 »
I had a few dents in mine as well (still do). I was able to straighten most of them out with some steel rods bent at various angles.
Sent from my SPH-D710 using Tapatalk
