Author Topic: BMW R90/6 Cafe  (Read 12892 times)
Offline ncologerojr
    • Catskill Mtn. Customs
Re: BMW R90/6 Cafe
« Reply #20 on: Jun 20, 2018, 14:37:33 »
Next I moved on to the tail cowl. It has to house the battery, which is large due to keeping the electric start. For this I chose to make a wire form buck. Not a great pic of t, but you get the idea. Next more aluminum was shaped.
Offline ncologerojr
Re: BMW R90/6 Cafe
« Reply #21 on: Jun 20, 2018, 14:40:48 »
After the cowl pieces were welded a flange was turned to add strength, a seat pan was bent and everything welded up.
Offline ncologerojr
Re: BMW R90/6 Cafe
« Reply #22 on: Jun 20, 2018, 14:42:44 »
The tank mounts, and tunnel were finished up and everything final welded.
Offline ncologerojr
Re: BMW R90/6 Cafe
« Reply #23 on: Jun 20, 2018, 14:43:49 »
Offline ncologerojr
Re: BMW R90/6 Cafe
« Reply #24 on: Jun 20, 2018, 14:48:22 »
Next I started on the under-tail details. A tight fit aluminum panel with a rubber seal will make up the battery tray. It will be bolted to the frame separate from the cowl so the cowl can be lifted off the battery for servicing. Another panel creates an area between the frame tubing for wiring/components. (Not the final hardware)
Offline ncologerojr
Re: BMW R90/6 Cafe
« Reply #25 on: Jun 20, 2018, 14:49:40 »
Bro I am right there w you.  Sure I enjoy going for a ride.  However, I leap out of bed in the mornings if thereís work to be done.
I am in awe of the work you and some others are doing.  Sometimes Iím surprised you all allow me to be here at all.
Thanks man, there are some very talented guys on here. Iím just a hack that likes working metal.
Offline Jimbonaut
    • Lost Apostle
Re: BMW R90/6 Cafe
« Reply #26 on: Jun 20, 2018, 14:57:09 »
Wow man, really enjoying watching this bike shape up - beautiful work
Offline ncologerojr
Re: BMW R90/6 Cafe
« Reply #27 on: Jun 20, 2018, 17:36:34 »
Thanks a lot man!
Offline ncologerojr
Re: BMW R90/6 Cafe
« Reply #28 on: Jun 20, 2018, 17:37:45 »
Today Iím working on the battery tray. Made a quick dimple die on the late to dress things up a little.
Offline irk miller
Re: BMW R90/6 Cafe
« Reply #29 on: Jun 20, 2018, 18:57:51 »
Are you going to stiffen up the cradle so it's not a rubber cow anymore?  Curious if that will get even worse (or better) now that it's a mono shock. Considering where your top mount is, I don't have as high of hopes.
