Author Topic: Black Knight..Brake upgrade  (Read 38227 times)
Offline trek97
Re: The Black Knight, Sketchy engine stand
« Reply #180 on: Sep 21, 2018, 23:57:42 »
I would worry more about it being top heavy on that work bench.  But a nice little stand otherwise.
It really doesn't want to tip too badly.  Im just hoping the workmate doesn't buckle, bend and fold over.
Its made from pretty chintzy stuff.  I shoulda sprung for the real deal Black and Decker - WM1000
« Last Edit: Sep 22, 2018, 00:01:26 by trek97 »
Offline Flugtechnik
  • My bike is not transportation, it is a respite
    • Nixon and Me
« Reply #181 on: Sep 22, 2018, 01:20:33 »
That is 13 times less sketchy than my engine stand.
Offline trek97
« Reply #182 on: Sep 22, 2018, 07:59:39 »
FLUG!!!  How you been bud?
Maybe only like 9.372 times less sketchy.   ;)
Offline trek97
Re: The Black Knight, Pleasant surprise inside
« Reply #183 on: Sep 22, 2018, 12:54:59 »
This makes me feel better.  ;D
Imagine that, a SS screw galded in the aluminum
Yup, dry as a bone.  Stupid
Someones been here before....
Repair
But not damaged...
Found #4 intake tappet lock nut completely loose.  :o
AWESOME!!!
Im seeing zero signs of wear.  :)
« Last Edit: Sep 22, 2018, 12:56:44 by trek97 »
Online 3DogNate
  • "You Meet the Nicest People on a Honda"
Re: Re: The Black Knight, Sketchy engine stand
« Reply #184 on: Sep 22, 2018, 13:10:33 »
Sweet! clean and reassemble (correctly) and get it back in the frame.
Offline trek97
« Reply #185 on: Sep 22, 2018, 13:22:11 »
Fresh clutch discs, plates and springs going in first.  New ignition points plate.
Clean pickup screen and new filter, drive sprocket, fresh little harness for the stator and field coils
Re-torque head bolts and adjust valves.     :)
Offline pidjones
« Reply #186 on: Sep 22, 2018, 13:38:44 »
That looks stable. BTW, I have had excellent luck with smooth SS threads in aluminum when I give them a couple coats of Neolube (graphite in alcohol) first. Cheap, rough SS threads will screw it up every time.
Offline trek97
« Reply #187 on: Sep 22, 2018, 13:55:31 »
Yea I like thread sealant w teflon its good up to 550 degrees F.  Never hardens up.
Really just about anything will work to prevent galling.  anti-seize, locktite...etc
The Stainless and aluminum combo is just the worst possible mix for galling.
« Last Edit: Sep 22, 2018, 14:02:37 by trek97 »
Offline trek97
« Reply #188 on: Sep 22, 2018, 13:56:35 »
Does anyone know,
Can I just pull the screen from the pickup?  OR do I need to pull the complete pickup?
Offline irk miller
« Reply #189 on: Sep 22, 2018, 15:53:12 »
I suggested what to do, but you don't want my advice.  LOL.  I'll say it again anyway.  If you remove it, the hardened rubber may crack, so be prepared to buy a replacement.  It's really nuts, but Honda put the same design pickup screen on the CB750.  Either rinse it clean or carefully and slowly pry it off and hope you don't crack the hardened rubber.  The screen is keeping the crap from going back up into the motor, so all the shit is on the side you're looking at.  I've been scraping my screen and rinsing it clean on my CB750, but I'm an idiot who half asses everything because I spend too much money on shitty motorcycles at swap meets.
