Quantcast
Author Topic: Black Knight..Brake upgrade  (Read 39915 times)
Offline Luugo86
  • '73 CB350, '78 XS650 Cafe Killer
    • ToadStool Cycle Co.
Re: The Black Knight, A 1975 400-four
« Reply #230 on: Sep 29, 2018, 21:32:18 »
That is an incredible job on that engine... can you PM me ur step by step method for how u got it looking so darn good?  Im about to clean a CB350 engine.. thanks man
Live to Die, Die to Live
Offline Brodie
  • Gold Coast, Queensland
« Reply #231 on: Sep 29, 2018, 22:12:06 »
You could just claim the smooth paint helps with heat dissipation and aerodynamics. Rat rod crowd should dig it.
Offline trek97
« Reply #232 on: Sep 29, 2018, 23:34:36 »
and
Thanks so much, and yeah,  Ill make a post in the morning.  Some guy from France asked me to do the same thing on FB.
Offline trek97
« Reply #233 on: Sep 29, 2018, 23:37:04 »
If the whole bike looked like crap it would just be another crappy looking bike.
Am I right?!?!   8)
Offline Brodie
« Reply #234 on: Sep 29, 2018, 23:40:01 »
Yep. Fine line between Rat rod and crap pot.
Offline Luugo86
« Reply #235 on: Sep 29, 2018, 23:44:32 »
and
 lol
... u know the shamwow guy cant do commercials anymore because a hooker bit his tongue out
Offline trek97
« Reply #236 on: Sep 30, 2018, 07:25:32 »
lol
Wow so gross.  What kind of hooker does it take to kiss THAT GUY?!?!?
Offline trek97
« Reply #237 on: Sep 30, 2018, 09:31:33 »
Thanks bud, and really no secret, pretty simple really...
Removed and cleaned all the cover gaskets surfaces
I washed it down w diesel fuel and small brass wire brush to knock of most of the grime, rinsing clean w water.
Then a boat load of Dremel wire brushes and little scotchbrite puffs to knock off the hard oxidation and smooth the aluminum.
SAFETY GLASSES AND A DUST MASK!   The cheap Dremel wire wheels throw wires out constantly.
https://www.amazon.com/gp/product/B01KO98PIK/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B01KFPO4BK/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
This is after cleaning...
I sandblasted the breather, oil filter, left side sprocket, clutch covers and oil pan.  Just the stuff thats was to wash ALL the sand out.
re-assembled all the covers (tight, using only 2 or 3 bolts) and stuffed paper towels in the intakes and exhaust ports
Flooded the whole engine w Brake cleaner.  (Do not use carb cleaner...they are not the same thing.). Brake cleaner ONLY
Blow it out and dry w compressed air.
Washed it w brake cleaner a 2nd time.  Blowing dry w compressed air.
Removed most bolts from covers.  Leaving just one bolt to hold each cover loosely.
Loose enough that the covers and Valve adj caps really dont touch the cases.    (Room for a playing card to slip in.)
I didn't mask off anything.  I got new seals for it.  So this will get replaced.
Irk turned me onto this Marbles Motors high heat engine paint.  I LOVE IT.  Same stuff I used on Rachels Hondamatic.
It looks nice and weathers well.
http://marblesmotors.com/product/honda-engine-cover-paint-matched-color-silver/
Actually its the same can (I Spray light enough to do the 2 engines w one can)
I dont use primer w this paint.  I have primered engines in the past but for this and the Hondamatic I didn't.
The first round coats are VERY LIGHT.  Almost just tinting the engine.
5-10 minutes.  Second round is a LIGHT COATS going in Criss-cross pattern to even it all out smoothly.
5-10 minutes. Third round,  is LIGHT coats.  Standing back - just fogging the paint on.  To a nice, smooth, even, wet finish.
If you spray too heavy - wet - close - it will look like shit.  So stand back a few inches more than normal.
Let it dry.
Pull the covers off and carefully wipe the gasket surfaces w paper towel and acetone or lacquer thinner.
Replace gaskets, seals along w replacing all the bolts w stainless steel coated with thread sealant.
Done.
« Last Edit: Sep 30, 2018, 10:03:06 by trek97 »
Offline Luugo86
« Reply #238 on: Sep 30, 2018, 12:00:39 »
   Thanks a lot for taking the time to type up that run down man.. Much appreciated.. I never would have thought to use brake cleaner
Offline trek97
« Reply #239 on: Sep 30, 2018, 12:05:39 »
Your welcome bud,
Yeah it really blasts between fins.  Just dont get it into your eyes!
Then the air compressor will really blow out all the mud wasps nests.
This engine was chock full of them.   ;)
