Author Topic: Black Knight..Brake upgrade  (Read 38260 times)
Offline pidjones
Re: The Black Knight, HOORAY its CARB DAY!!!
« Reply #280 on: Oct 08, 2018, 21:59:46 »
You should hold on to the old float needles and seats if they are original. Just in case, you know.
Offline trek97
« Reply #281 on: Oct 08, 2018, 22:05:11 »
Oh yeah, I hang onto everything.
 its looking like the main #75 needle seats are going to go the same way too.
Ill see if Honda still offers the original sized O-rings for this stuff.   >:(
Offline trek97
« Reply #282 on: Oct 08, 2018, 22:13:25 »
The O-ring kits are available from Honda.
But its not the original part number.   (new Honda parts are probably the same as what I already got)
So Im gonna stick w what I got here, until I run into issues w tuning.
Offline trek97
« Reply #283 on: Oct 10, 2018, 08:50:52 »
Slides and needles look good
Float valve seat springs in correctly.
Overflow tubes inspected for cracks.  Dont need a repeat of the Hondamatic experience.   :P
Offline 1fasgsxr
« Reply #284 on: Oct 10, 2018, 15:17:31 »
Let me know if you need any carb parts. I have a box full of pieces from my 350.
Offline trek97
« Reply #285 on: Oct 10, 2018, 18:26:28 »
Thanks bud, everything here appears to be in good condition.   But if I do Iíll get ahold of you.
Offline teazer
« Reply #286 on: Oct 10, 2018, 19:37:54 »
If those carbs have the same 6mm x .75 thread on the float bowl drain screws as most other Hondas of that period, you can use vacuum adapters to check fuel level.  CrazyPJ sells them as vacuum adapters for CB360s but I just found out that they also work fine for checking fuel levels on Suzuki GT550s and early GT750s as well as CB750 SOHC and CB77 and 160s
Offline canyoncarver
  • 'hacking is learning'
« Reply #287 on: Oct 10, 2018, 20:02:04 »
LOLOLOL. Yes Kelly its Loud like a Fire Engine crashing into a Freight train crashing into a 747.
Ha!
Offline trek97
« Reply #288 on: Oct 10, 2018, 22:35:21 »
I will check into that.  I was thinking about figuring out how to make an external fuel level "Thingy".  8)
THANKS!!!!
Offline trek97
« Reply #289 on: Oct 10, 2018, 22:44:20 »
I was gonna swap in new mix adjusters...NOT!!!
As I Threaded in the first NEW one, it popped back out a couple threads under the spring pressure!!!
Measuring external threads...
Originals...
Floats straightened and squared up pretty nice.  Set to 20mm.
Complete w factory plastic caps on mix adjusters and SS hardware.
