Author Topic: Black Knight..Brake upgrade  (Read 36831 times)
Offline irk miller
Re: Black Knight...Sparckmoto.com saves my sanity
« Reply #470 on: Nov 22, 2018, 01:39:09 »
Dynatek sends scotch loks with their Dyna S kits for the power feed.
Offline trek97
« Reply #471 on: Nov 22, 2018, 08:47:25 »
Offline jpmobius
  • where does this go?
Re: Black Knight...SUPERTRAPP!!!!
« Reply #472 on: Nov 22, 2018, 14:16:14 »
That sounds so smoooooth. With all of the work in it, it should, right?
Does the Teflon paste really work? At work, we had a lot of SS 1/4" NPT fittings into aluminum castings that had been "sealed" with teflon tape. They carried helium, and all leaked. When pulled apart to repair, they had all galled and ripped aluminum threads out with them. Luckily they were shallow enough to be retapped and sealed with blue refrigerant sealant (LeakLok). Of course, NPT threads have a lot of pressure on them. On SS into aluminum bolts, I've been using a product called NeoLube - collodial suspension of graphite in isopropyl alcohol. When the alcohol evaporates, it's like graphite plating. Fantastic for SS to SS at really high temps, and so far has worked for me on SS in aluminum. You MUST use lock washers, however! (And reduce torque, as it is very slick and easy to draw threads right out.)
Stainless to stainless is always a problem.  Antisieze with copper seems to be reliable on bolts, keeping in mind the weakness and gummy nature of stainless and using proper for stainless torque.  Pipe threads require nickle.  Teflon tapes are made with nickle embedded in them for this very purpose are readily available, and are actually a very good thing to have around for non stainless applications, though a bit pricey.  Mandatory for stainless!!  Large diameter stainless pipe threads (4" dia plus) are very hard to reliably seal.  Teflon/nickle tape and teflon pipe dope has proven the best in my own experience along with great care making/inspecting the threads to begin with.
Personally, I have never had any issues with stainless fasteners in aluminum castings.  I think that this is commonly of concern due to corrosion of the aluminum, and while there is some galvanic corrosion from the inherent difference in electrical potential of the dissimilar materials, it seems to be fairly unimportant with bikes.  I pretty much universally use blue threadlocker on everything "ordinary", in this case stainless bolts (which I use universally for non critical applications) in aluminum, castings, i.e. case covers to crankcase.  I believe this works well because the threadlocker seals out moisture and reduces the contact between the two materials.  I absolutely never see a problem even disassembling parts put together for 20+ years.  Bikes disassemble themselves without threadlocker in my experience!
« Last Edit: Nov 23, 2018, 12:55:50 by jpmobius »
Mobius
Offline trek97
« Reply #473 on: Nov 22, 2018, 14:40:21 »
Theres some awesome info in there.  Thanks!   8)
I dont know that you celebrate Thanksgiving, but if you do, Wishing you the best ever.
A couple paragraphs on Stainless thread galling which touches on the use of PTFE prevention.
https://www.fastenal.com/content/feds/pdf/Article%20-%20Galling.pdf
« Last Edit: Nov 22, 2018, 14:46:22 by trek97 »
Offline Maritime
« Reply #474 on: Nov 22, 2018, 15:50:12 »
Yes, I wont be using those either. And I still need ro check the magnets for you
Offline pidjones
« Reply #475 on: Nov 22, 2018, 21:45:55 »
Alternate for the Fastenal link: https://www.fastenal.com/en/72/galling
Offline CrabsAndCylinders
  • Careful With That Axe Eugene
« Reply #476 on: Nov 24, 2018, 14:17:35 »
Thanks for the galling posts, guys.
Lighter, Quicker, Faster.
ZX-14, 900F x 2, 1100F, R100, CBR600, SR500, GT500, RZ350, KZ1000 x 2, Moto Guzzi Lemans lll, CBX550, RD 350, 750 SOHC police special, RG250, TL1000R, GT750, KTM Super Duke 1290 R, Harris/Z-1, Norton 750 Commando, Green 77 KZ650
Offline trek97
Re: Black Knight...First ride video.
« Reply #477 on: Nov 24, 2018, 20:18:22 »
The weather is going to turn foul soon.
I did the bare minimum to get a ride on this thing.
No wire harness, No Lights, No front brake.
I ran a single wire from battery + to kill switch and back to coils.  A 2nd wire from Battery neg to an engine cover bolt.
Duct taped iPhone to headlight bucket for the ride.  sorry bout that.
« Last Edit: Nov 24, 2018, 20:20:42 by trek97 »
Offline pidjones
« Reply #478 on: Nov 24, 2018, 20:55:23 »
That will have to carry us until Spring, I guess. Congrats on the 1st outing!
Offline trek97
« Reply #479 on: Nov 24, 2018, 21:03:56 »
Thanks bud,  Yup, This is gonna be one long cold winter.
