Author Topic: Just picked up a cb360. Stuck engine help.  (Read 907 times)
Offline ryan_289
« on: Jul 11, 2018, 00:09:55 »
I just picked up a 76 cb360 from a guy at work. He claimed he picked it up in a package deal and the engine is stuck.  I got it home tonight and the po had filled the crank case with what smelled like transmission fluid.  I stuck my cord camera down the spark plug holes and they were dry. I filled the cylinders with corrosionx and will rock it around over the next few days. If that doesn't work are there any other suggestions to help unstick it?   Here are a few pics. Excuse the mess, I'm in the middle of a few projects.  My goal is to end up with a tracker/scrambler type bike.  This is my first motorcycle in about 20 years!
Sent from my SAMSUNG-SM-G891A using Tapatalk
Offline Spoonz
Re: Just picked up a cb360. Stuck engine help.
« Reply #1 on: Jul 11, 2018, 00:43:48 »
If itís stuck, once you get it unstuck you are probably going to need to rebuild the topend at least.
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #2 on: Jul 11, 2018, 02:25:43 »
ATF and acetone 50/50 in the cylinders. Fill em up. Wait a week. See if it turns over. Donít force it either way.
Like spoonz said youíll probably want to rebuild the top end, at the minimum rings and a hone on a stuck motor...so you can just pull the head off, break the jugs free with a rubber mallet or deadblow, place some blocks underneath to raise it off the crankcase and then tap the pistons down with a block of wood.
'78 Honda z50 - http://www.dotheton.com/forum/index.php?topic=76059.0
Offline MiniatureNinja
« Reply #3 on: Jul 11, 2018, 03:02:35 »
If the engine is stuck, there are bare minimum things that you will need to do... go ahead and pull the motor, take it apart. You can free pistons with a good soak of marvel mystery oil, just let them soak in there for a few days. Rock back and forth gently, motor like to spin counterclockwise but a few degrees back wont hurt it.
'75 Honda CB360 - thread
Offline ryan_289
« Reply #4 on: Jul 11, 2018, 17:05:59 »
Any recommendations on rebuild threads or videos?  I've never been into a motorcycle engine.
« Reply #5 on: Jul 11, 2018, 17:57:20 »
Sderbyshire thread just below yours, pjcrazy tons of info, mine in my signature, trek, there really are a ton of them on this forum alone
Offline ryan_289
« Reply #6 on: Jul 11, 2018, 22:51:31 »
Success!  Went out to the shop and put it in high gear and she broke loose.  Still may need a top end rebuild but now it will be easier to take apart.  I'm going to at least try and get it to fire off first though.
« Reply #7 on: Jul 11, 2018, 22:55:31 »
if the engine was stuck, you run a pretty serious risk of grenading it - it turns over, that's great... is firing it up worth it?
Offline trek97
« Reply #8 on: Jul 11, 2018, 22:57:45 »
I would pull the head cover and make sure everything is working smoothly, cam is turning, all valves working, tons of lube...etc.  check valve clearance.
Then fire that thing up.
« Last Edit: Jul 11, 2018, 23:02:38 by trek97 »
Offline ryan_289
« Reply #9 on: Jul 11, 2018, 23:28:08 »
Are motorcycle engines that delicate?  I've unstuck old flathead jeep engines before and fired them off with no issues. Serious question, I've never worked on a small engine.  I guess they are running quite a bit faster than an old jeep with smaller parts to boot!
