Author Topic: 1982 CB750F... The resto-not  (Read 25270 times)
Online Jimbonaut
    • Lost Apostle
Re: 1982 CB750F Resto-mod. At least that's the current plan.
« Reply #31 on: Aug 06, 2018, 13:44:07 »
So that’s what that thing’s called. Learn something new every day 🧐
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #32 on: Aug 06, 2018, 13:45:30 »
I only know the name from looking it up for popping dents on a motorcycle tank  ;D
Online Jimbonaut
    • Lost Apostle
« Reply #33 on: Aug 06, 2018, 13:59:29 »
Better that than for spiking blood pressure
Offline irk miller
« Reply #34 on: Aug 06, 2018, 14:24:34 »
Cheers Irk. Any idea what the differences between the carbs are?
Hard to say.  I've never see anything about your particular E carbs.  They might be Euro spec or something, but all the VB42 carbs (in the US) are jetted the same and share common specs on paper:
3 Jet Vacuum Slide:
EPA Spec (US), Hidden Emulsion Type Idle Mixture Screw, Non-Replaceable Slow Speed Jet (Some Models) Non-Adjustable Jet Needle (All Models) Air Cut Valves (All Models), Twin Sequentially Functioning Main Jets (68/102), Slow Speed/Pilot Jet (35), Accelerator Pump (All Models)
Online Jimbonaut
    • Lost Apostle
« Reply #35 on: Aug 06, 2018, 14:30:48 »
Cheers man - from what I've read the number after VB (in this case 42) refers to the size of the venturi.  Jets-wise, these carbs have been fitted with 68 primary and 100 secondary.  But the Clymers indicates the F should have 102 I think.
"Dabbled with" definitely applies to this bike.
Offline irk miller
« Reply #36 on: Aug 06, 2018, 14:36:38 »
That's correct.  It's always Venturi size at the slide.  And definitely should have a 68/102 in stock form.
Online Jimbonaut
    • Lost Apostle
« Reply #37 on: Aug 06, 2018, 14:48:42 »
The bike has a 4 into 1 Kerker exhaust - may that be why the jetting has been adjusted?
Online Jimbonaut
    • Lost Apostle
« Reply #38 on: Aug 06, 2018, 23:21:29 »
Carb hose question - when I pulled the carbs, both hose A and hose B were connected to the carb body at one end but not the other -
here's another shot -
But on my other CB750 there's only one hose that's connected to both ports on the carb.  So I did the same with this, ditched one tube and looped the other -
Is that correct?
Hooked up the carbs, tank, airbox again, fired it up - seems to idle ok but as soon as I crack the throttle the revs stay high.  I checked all the boots to see if there was a vacuum leak but they seem ok, and the throttle cable isn't binding.  Any ideas what could be causing this?
Offline irk miller
« Reply #39 on: Aug 06, 2018, 23:44:30 »
That's your automatic fuel valve.
The tube in your fingers is an air line.  The tube in your thumb is a vacuum line.  Your high idle sounds like maybe the carb is running out of fuel and going lean.
