Quantcast
Author Topic: 1982 CB750F... The resto-not  (Read 33149 times)
Online Jimbonaut
    • Lost Apostle
Re: 1982 CB750F... The resto-not
« Reply #610 on: May 20, 2019, 14:21:44 »
Indeed - teachers come in all shapes and sizes Nybz.  And it's a fool who thinks otherwise.  I took a bit of a beating over there, but I'm totally ok with that.  The CB1100f forum is a different beast than DTT but no worse off for it.  The guys over there know their onions and no mistake.  They've forgotten more about the SuperSport than I'll ever know.  Amazing help and resource.
So, a productive few days.  Got the newly bored-to-823cc and honed block back, completely with repaired fins, came back mint -
(need to get a photo of the fins, will do today).  Someone over on the other forum mentioned S-100 and pressure washers.  I have the S-100, and just last week my neighbour offered me his washer whenever I needed it.  Penny drop.  Balconies could use a good going over too so made that happen -
- then sprayed a load of S-100 and waited 20 mins for it to do it's thing.  Kids, I discovered the coolest way to get totally soaked this summer!  It's easy - line up your air-cooled cylinder block (the more cylinders the better) on a stool at about knee height.  Doesn't matter what engine it comes from, the important take away here is air-cooled.  It's all about the fins you see.  Stand close - really close - and have at it with the pressure washer.  All those fins, nooks and crannies will have you Absolutely Soaked almost immediately.  It's great.  Fun times.
Dammit if the S-100 didn't work a charm though, especially between the cylinders.  Wiped the bores down with some engine oil to prevent flash rust, job done.
After some encouragement and gentle persuasion/peer pressure figured f*ck it let's split the cases.  After the drama of the last post, it became very obvious that the rotor really does need to come off when attempting the job.  Turns out the rear axle of this bike is a perfect fit into the rotor and assumes admirable chops as the pulling tool.  Once I got the rotor bolt out, threaded in the axle and whaled on the thing with a heavy hammer until eventually the rotor popped off -
- and the cases split no pasa nada -
Pulled the main crankshaft bearings, the upper bearings all looked good -
but the backs of them are showing copper -
- does that matter?
The lower bearings look ok but two are showing copper -
In that case, do I need to replace all the lower bearings? Or just the two showing copper?  They're about $10 each so on the big scheme of things, doable.
The con rod bearings all look good -
I'm going to replace the two cam chains, some o-rings and oil seals, I'm not sure about the primary chain, and also want to replace the rubber dampers in the primary shaft.  Anything else I should be on the look out for?
« Last Edit: May 20, 2019, 14:32:26 by Jimbonaut »
Offline wozza
« Reply #611 on: May 20, 2019, 19:54:06 »
As your down that far Id replace all the bearings and have the crank done as well..copper on the back is normal (AFAIK) as they only plate the running surface..
Nothing worse than spending all that time rebuilding a motor and have a bearing spin a couple of 100 kays/miles down the road.To my eyes those conrod bearing look pretty worn Id also be looking at the oil pump circuit as well ;)
« Last Edit: May 20, 2019, 19:56:52 by wozza »
Offline Popeye SXM
  • Also used for MX
« Reply #612 on: May 20, 2019, 21:22:23 »
Having gone down the rabbit hole this far... is seems daft (to me at least) not to change all the bearings. All depends of course how long you plan to keep the bike. I do admire your will to make this bike wright, keep up the great work
Online Jimbonaut
    • Lost Apostle
« Reply #613 on: May 20, 2019, 21:40:44 »
Cheers gents - I have it on good authority that there's no need to change all the bearings if they're not worn but I can't help agreeing with you, got this far, may as well.  Still, I'd like to learn whether it's a must or not - there are only two lower main bearings that are showing copper, and none of the rod bearings.
Removed the lock bolt on the primary shaft, which involves jamming a flat head screwdriver between the split gear and the crankcase.  Busted a small pry bar but eventually loosed the bolt.  Involves putting the gear back in the case and tightening up a few case bolts to hold it in place, then do your worst -
With the bolt removed I could then remove a gear and a few washers but came up stuck against the bearing that also needs to be removed.  The Clymers is very vague about this, just says to remove the bearing.  Heat gun?  That thing is jammed on there tight.
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #614 on: May 20, 2019, 23:27:29 »
You'll want to use a bearing puller if you care to reuse that bearing. If you don't have one, you can try freezing that whole assembly, pulling it out of the freezer once its good and cold and hitting the bearing with a torch and the bearing should slide off.
Online pidjones
« Reply #615 on: May 21, 2019, 08:00:00 »
Not much more help on disassembly, but pretty good on the bearings, here is a link to the Honda FSM chapter for this: http://www.cb1100f.net/Other/CB750FManual/Honda1979thru83CB750ServiceManualChapter12CrankshaftPrimaryShaft.pdf
You might need to join the site, but it is free and has great stuff for F bikes.
Online Jimbonaut
    • Lost Apostle
« Reply #616 on: May 21, 2019, 10:21:34 »
Thanks man, yeah I’m a member of that forum and I already have the FSM - doesn’t really give much info on how to remove the bearing though. The forum’s been acting up a little recently but I’ll post my q in there once it’s back up and running.
I’ll give AdvCo’s suggestion a try - if I apply heat onto the frozen bearing do I run the risk of damaging the bearing in any way? And am I right in guessing that the bearing itself is lubricated by the engine oil, not grease?
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #617 on: May 21, 2019, 10:31:51 »
Nope, think of it like you're starting a bike in frigid temps. Your cylinders and valves will go from icy cold to hot in short order.
Yes, all the bearings in the engine are lubed by oil.
Online Jimbonaut
    • Lost Apostle
« Reply #618 on: May 21, 2019, 11:09:57 »
Good point.  I don't have a torch per se but the missus has a mini blowtorch she bought for making the sugar go all crispy and fancy on her home made creme brűlées.  Unless she makes the things when I'm not around (which would suck), she's never, ever made one and the lighter's sitting on the kitchen shelf unused.  That'll do nicely.
Online Jimbonaut
    • Lost Apostle
« Reply #619 on: May 21, 2019, 19:42:09 »
Primary shaft's in the freezer, cozying up to some bison burgers and fish fingers - I'll leave it in there overnight and then hit the bearing with the blowtorch over breakfast.  Pretty sure that's what kitchens are for, and if they're not then no doubt I'll find out the hard way.  Again.
