Author Topic: 1997 BMW F650 ST Bluebird - Repair, maintain, ride.  (Read 9129 times)
Offline Hurco550
Re: 1997 BMW F650 ST Bluebird - Repair, maintain, ride.
« Reply #30 on: Sep 14, 2018, 16:16:59 »
its funny you say that, and I wonder where the "turn" came in design, because my 76 r90/6 BMW is really one of the most well thought out machines to work on that I've ever owned. Now my buddy drives a late model (2010 I think) bmw something or other car, and talk about an overcomplicated piece of kit.
~ bradj
Offline Maritime
« Reply #31 on: Sep 14, 2018, 16:20:44 »
Thank god most times it doesn't break but man when it does it's fucking crazy complex to fix.
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #32 on: Sep 14, 2018, 16:25:51 »
Yeah Mike, its a big single with 2-into-1 cylinder intake and 2 Mikuni BST33's. I know others have fit different carbs (irk's TMs) but not sure whats out there on single carbs.
Regarding the simplicity - the motor is made by Rotax in Austria and the entire bike is built/assembled by Aprilia in Italy. That should say a lot  ;D
Online irk miller
« Reply #33 on: Sep 14, 2018, 16:35:11 »
SO this is a big single with 2 carbs and 2-1 intake? Can you swap it out to a single carb intake?  That would have to be easier to tune etc? Or maybe not. but one thing I know about German shit, it's usually over complicated when it doesn't need to be.
I have a 2-into-1 intake for these.  Just need a carb to fit the wishbone in the frame.   The intake is off of a DS650 Bombardier.  This Rotax motor is incredibly reliable, very well engineered, and not complex at all.
If you popped the clutch when you pulled the lever, make sure you have the adjustment right.  That's what it does when the lever is in the wrong starting position.
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #34 on: Sep 14, 2018, 16:47:53 »
You mean the lever/arm on the LH side cover (where the cable end attaches to?). It may need to be turned another notch.
Online irk miller
« Reply #35 on: Sep 14, 2018, 16:53:14 »
As you know, since you had to replace it, the clutch actuator is a worm gear.  The actuator shaft (the part that the cable turns) needs to be in the engaged position when the arm and cable is put on so that when you pull the lever it actuates.  Before you put the arm and cable on, you can spin the worm gear completely in both directions all the way to the end of the gear, so it's easy to get confused where it needs to be to hook up the cable.
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #36 on: Sep 14, 2018, 17:04:13 »
Yes, I realized that the first two times I put that back together. The clutch seemed to engage/disengage as normal before I attempted it while the bike was running. Now there seems to be some slop between the actuator and the actuator shaft (which doesn't seem right at all). I'll post a video later. I really don't want to drain the coolant and pull the entire cover off again.
Is there a specific position that the shaft needs to be at when the cover is installed? Or is it all just relative to the arm and cable once its all back together?
Online irk miller
« Reply #37 on: Sep 14, 2018, 17:08:50 »
Don't give up on this thing.  They're super reliable once all sorted.  You just bought into an abused bike.
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #38 on: Oct 04, 2018, 09:36:04 »
So the last time I ran it, there was some major vacuum leak issues going on. I hate pulling the carbs on this thing so I've been putting it off.
Last night I pulled the carb rack and removed the intake manifold to check it for cracks. Some minor cracking inside the boots but nothing that went all the way through and the rubber is still soft and pliable. I smeared a thin coat of Yamabond between the manifold and the head and reinstalled it. Normally I would just do 1 thing at a time but if I never pull these carbs again I'll be happy. So I blew out the jets and passages again, and double checked the diaphragms for cracks. Everything there checked out, so I put a thin coat of Yamabond on the mouths of the intake boots where the carbs seat. Re installed carbs, I'll let the Yamabond set up and test fire after work today to see if its still leaking.
If it is I guess I'll source a new intake manifold.
Offline JustinLonghorn
« Reply #39 on: Oct 04, 2018, 11:47:37 »
Fingers crossed, my man.
Into The Sunset, CB750 build
TT500 the Animal
