Quantcast
Author Topic: 1997 BMW F650 ST Bluebird - Repair, maintain, ride.  (Read 10579 times)
Offline Jimbonaut
    • Lost Apostle
Re: 1997 BMW F650 ST Bluebird - Repair, maintain, ride.
« Reply #20 on: Aug 21, 2018, 11:30:08 »
Me (KLR) and mate (DR) went for a midnite ride around the city last night - dual sports on quiet city night streets is f-u-n.  You're gonna have an absolute riot on this thing mate, hope you're in the saddle soon!
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #21 on: Aug 24, 2018, 15:59:26 »
Was able to get the cooling system filled up, oil system bled and primed and filled up with oil. Hooked up the bottle and she fired up after 2-3 cranks. Seems to be running well. A little backfiring at low RPM but I may have the idle speed set too low. It’s also puking petrol through the T inlet to the carbs so I’ll have to pull the carbs again and adjust that to fix that issue, may be contributing to the backfiring as well if it’s running too rich. I also had a couple of vacuum lines (emissions stuff I think) disconnected so I’ll straighten that all out later.
Going out of town for the weekend so I’ll get back on it next week. Fix carbs, reinstall the fuel tank and seat and we should be on the road.
Getting closer!
Offline JustinLonghorn
« Reply #22 on: Aug 28, 2018, 18:33:26 »
My man!
Into The Sunset, CB750 build
TT500 the Animal
Offline trek97
« Reply #23 on: Sep 02, 2018, 10:38:05 »
Thats great dude.
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #24 on: Sep 14, 2018, 09:19:18 »
I tried to take it for a test ride yesterday, but its running like garbage and backfiring like crazy. Found some vacuum leaks around the carb boots so I guess I have to pull them off again and check the intake boot. Will also check the exhaust headers for leaks, the nuts on the studs for the exhaust only call for 10 nm torque which is barely even tight so I may snug those up some more now that its been heat cycled a few times.
ALSO. I pulled the clutch in and something popped in there and I completely lost the lever. I hope nothing broke  >:(
Going to have to pull the LH cover off and investigate. Probably going to have to drain the coolant again to get in there.  ::)
Offline Maritime
« Reply #25 on: Sep 14, 2018, 09:37:22 »
Poo, hope it's nothing serious.
Offline trek97
« Reply #26 on: Sep 14, 2018, 14:27:38 »
Dang dude.  All that stinks.
Offline Jimbonaut
    • Lost Apostle
« Reply #27 on: Sep 14, 2018, 14:56:51 »
These things are sent to test us.  If in doubt, get the hammer out.  And hit things.
Offline Maritime
« Reply #28 on: Sep 14, 2018, 15:49:39 »
SO this is a big single with 2 carbs and 2-1 intake? Can you swap it out to a single carb intake?  That would have to be easier to tune etc? Or maybe not. but one thing I know about German shit, it's usually over complicated when it doesn't need to be.
Offline Jimbonaut
    • Lost Apostle
« Reply #29 on: Sep 14, 2018, 16:09:26 »
Aint that the truth.  I took apart a BMW mid 80's K100 throttle assembly at work the other day, and there was some kind of chain and gear assembly in there connected to the throttle cable.  Great when it works, bit of a nightmare when it went south.
