Author Topic: 1997 BMW F650 ST Bluebird - Repair, maintain, ride.  (Read 10535 times)
Offline Maritime
Re: 1997 BMW F650 ST Bluebird - Repair, maintain, ride.
« Reply #130 on: May 01, 2019, 09:38:37 »
Oh and the boots, do they have a lip on the soles? I have that and it is how I need to shift most bike as my ankle won't go under the shifter, once you get used to it you can shift pretty smooth with the edge of the sole instead of the toe of the boot when the boots are really stiff and your ankle doesn't move much.
Offline irk miller
« Reply #131 on: May 01, 2019, 09:41:17 »
MX boots don't bend.  You move the shifter up to get the boot under it.
Offline Maritime
« Reply #132 on: May 01, 2019, 09:45:15 »
yeah but if they have the lip you can use it to shift too if the shifter won't move enough to work, some bikes even one tooth change and the shifting gets shitty in one direction or the other. Just an option I discovered after becoming a gimp.
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #133 on: May 01, 2019, 09:46:02 »
Here are the boots. They flex a bit so I do have some movement in the ankle. The toe is just a lot taller than what I'm used to. When I put the shift lever back on I may have put it in the wrong position.
Offline Maritime
« Reply #134 on: May 01, 2019, 09:47:48 »
Ok on those you need to move the shifter. The ones Levi and I have, the sole has an edge about 1/4" wide and it catches the shifter really nice. I could shift the GS1200 BMW that way easily without moving the shifter position.
Offline Jimbonaut
    • Lost Apostle
« Reply #135 on: May 01, 2019, 09:57:56 »
I have similar boots and I found moving the shifter position made getting the boot under there way easier.  Bit of a pain in the ass when I'm rocking the Converse for a quick trip to Canadian Tire but dems da breaks.
Offline Hurco550
« Reply #136 on: May 01, 2019, 10:01:16 »
I wear those boots or high top steel toe boots 99.9% of the time I ride. They are similar enough in "height" that I never really have to adjust things.
"If you want safety and sanity don't mess around with choppers to begin with and don't come crying to me for recommending something that broke down the line. You're going to be the "builder" so use your own judgment and build to you own personal levels of safety and sanity." - Chopper Handbook
Offline SONIC.
« Reply #137 on: May 01, 2019, 10:39:06 »
Yep move the shifter.
makes quick jaunts in tennis shoes annoying though.
(I see that as a good thing as now I just put the boots on to avoid the annoyance of having to lift my whole leg to shift without them).
Offline canyoncarver
  • 'hacking is learning'
« Reply #139 on: May 01, 2019, 11:45:55 »
I put an slightly longer than stock aftermarket shift lever on my KLR.  Took a try or two to get it right for my boots.
