Author Topic: ‘68 Honda CL450 - First Build  (Read 2847 times)
Offline Ethan
« Reply #30 on: Aug 08, 2018, 01:41:42 »
Ha!🤣  Hint: Total rookie mistake...
« Last Edit: Aug 08, 2018, 01:50:53 by Ethan »
Offline MiniatureNinja
Re: ‘68 Honda CL450 - First Build
« Reply #31 on: Aug 08, 2018, 01:54:52 »
The top half of the case.
Im not picky, Budweiser is fine
If that isn't the top half in the photo something is way wrong
'75 Honda CB360 - thread
Offline teazer
« Reply #32 on: Aug 08, 2018, 02:32:26 »
Cam chain
Selector forks
Gear change cam
Anything else?
Offline cxman
« Reply #33 on: Aug 08, 2018, 07:18:12 »
where is the cam chain?
1978 CX650 Super Deluxe
1979 XS1100 Special
1974 xl350
1983 cx650 Custom
1973 cb750
1980 cb750
1981 cb650
1982 cb900 c
1974 kawasaki 350 bighorn
1983 GL1100 aspy full dress
1983 GL1100 Nekid
and a bunch of others
Online Hurco550
« Reply #34 on: Aug 08, 2018, 08:23:27 »
Ha, your right. Next round is on me.
~ bradj
Offline Ethan
« Reply #35 on: Aug 08, 2018, 10:38:16 »
Looks like I owe Teazer a beer!
I put the cam chain in after this was taken. What I forgot were the parts I left in the parts washer.  Doh!
Guess I know what I’m doing this weekend...
Sent from my iPhone
’68 Honda CL450
« Last Edit: Aug 08, 2018, 10:50:46 by Ethan »
Offline teazer
« Reply #36 on: Aug 08, 2018, 11:03:07 »
Build enough motors and you will learn from all the mistakes and forgotten parts.....
You're doing fine so far.  Just take your time and be kind to yourself when something doesn't go the way you expected it to and you'll be fine.
Offline Ethan
« Reply #37 on: Aug 08, 2018, 11:06:31 »
Thanks Teazer.  I figured I would be doing things a couple times at least.  Just the first re-do of many to come...
I definitely had some case sealant squeeze out when I put the two halves together.  I'm hoping I can do a better job this time and keep it clean on the inside this time.
Any suggestions/tips for getting the oil separator pan out?  I wasn't able to get it out to fully clean the bottom of the case.  Figure if I'm pulling it apart again I might as well try to get it totally clean.
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #38 on: Aug 08, 2018, 11:17:01 »
I believe you just have to push the steel down to relieve the pressure on the rod, pull the rod out from the side to get those trays out.
Don't worry too much about it. I had to separate the cases on my first engine build 3 times.  ;D
Offline teazer
« Reply #39 on: Aug 08, 2018, 11:32:08 »
Looks like your has the two screws and four rivets to hold the windage tray in place.  Earlier models had the long rod through them and were easier to remove.
You would have to drill out the rivets and probably best to tap the standoffs and use bolts in place of rivets.
Google CB450 windage and you will find some threads on hondaTwins forum.
