Author Topic: Dohc Cb750f: possibly a valve issue  (Read 10496 times)
Offline SquidHunter
Re: Dohc Cb750f: possibly a valve issue
« Reply #170 on: Aug 14, 2019, 13:09:58 »
If you have FSM, check axle is fitted into wheel properly. It's very easy to fit it from the wrong side and have the wheel off centre
I do have the fsm, and the wheel and axle are mounted and torqued properly. It doesnít say anything in there about any alignment issues. However, I believe I found the noise. Iím thinking itís the speedo gear low on grease. Iím planning on deleting it anyway
