Author Topic: CB360 w/slow crank after rebiild  (Read 706 times)
Offline stu.belshe
Re: CB360 w/slow crank after rebiild
« Reply #10 on: Aug 14, 2018, 16:06:49 »
Appreciate the help, I'll update after some testing.
'72 CB350
'74 CB360
View my builds and bikes on Instagram @ instagram.com/standardvmoto/
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #11 on: Aug 14, 2018, 16:12:07 »
Sounds pretty unlikely that you'd have two bad starters showing the exact same symptoms. I would definitely look at the wiring.
'78 Honda z50 - http://www.dotheton.com/forum/index.php?topic=76059.0
Offline stu.belshe
« Reply #12 on: Aug 14, 2018, 16:13:46 »
I agree, and given that almost the ONLY wiring on the bike that can go pseudo wrong, it has to be ground. if any of the other connections (of which there are few) I would get no response at all.
'72 CB350
'74 CB360
Offline irk miller
« Reply #13 on: Aug 14, 2018, 17:54:12 »
How much does the voltage drop when you're cranking?
Offline stu.belshe
« Reply #14 on: Aug 14, 2018, 20:40:22 »
Thanks, Iíll check that as well when I get a chance. Would that be an indicator of any other issue besides the battery?
'72 CB350
'74 CB360
Offline MiniatureNinja
« Reply #15 on: Aug 14, 2018, 20:54:58 »
Starters spin ok off the bike? I had a starter with a shim in the wrong spot that wouldn't spin for shit.
'75 Honda CB360 - thread
Offline stu.belshe
« Reply #16 on: Aug 14, 2018, 21:02:19 »
It seemed to, seemed to have plenty of juice. It seems like itís spinning ok, just slowly. Like itís pulling something heavier than itís supposed to.
'72 CB350
'74 CB360
Offline irk miller
« Reply #17 on: Aug 14, 2018, 22:28:00 »
Voltage drop will indicate an issue with either your battery or the circuit.  If your battery checks out at 12.6v and you know it has proper cca, but you get more than .5v voltage drop during starting, then you most likely have an issue in your wiring.
« Reply #18 on: Aug 14, 2018, 22:42:19 »
also could be a bad battery - voltage or not - batteries sometimes lose their "umpfh" (amps) which would be evident if voltage drops too far
Offline irk miller
« Reply #19 on: Aug 14, 2018, 22:55:23 »
That's why I said if the battery checks out.  He also said in the beginning of the thread that it's a new car battery.
