Author Topic: CB360 from rat cafe to real bike!  (Read 2255 times)
Offline MiniatureNinja
« on: Aug 19, 2018, 20:37:36 »
I bought a CB360 a couple years ago that needed some work
this is how it started when I got it, recently survived an electrical fire due to lithium battery without the properly upgraded charging system
I built a makeshift workbench and began the dissasembly - motor was in decent condition but I opted for a rebuild, glad I did - you'll see why
some in betweens:
moved the project indoors to my friend's garage where we have a welder, drill press, other tools and some bikes in various states of awesomeness
did some mock up of the frame after a lot of input from members here about the rear suspension that I should have never attempted but did anyway
painted frame and then began assembling the parts and engine into the frame:
PAINTED it:
and the results are below with specs!
'75 Honda CB360 - thread
Re: CB360 from rat cafe to real bike!
« Reply #1 on: Aug 19, 2018, 20:42:31 »
Paint is Krylon Satin Jade - covered with spraymaxx 2k glamour clear
rear cowl and seat is a Dime City Cycles "brass cafe" chopped to all but the cowling part and shortened about 6 inches
Engine Modifications:
Bored out to 378cc (used lighter pistons from an 82 Suzuki GS850)
Extensive modifications to oil system and clutch
Rick's MS High Output Stator
Rick's MS Hotshot Rotor
KPMI oversized valves and Titanium Springs
Mildly Ported Head
PJ - modified CV carburetors
Speedy Seigl Racing header flanges
Modified Exhaust Headers
Lani's Custom Copper Gaskets
Rebel Gears 520 Chain conversion
Frame Modifications:
Detabbed
Shortened rear subframe
Custom shock mounts
Shed over 12 lbs off the frame alone
Suspension Modifications:
Rear 3way reservoir shocks
Extended swingarm, enclosed
Bronze swingarm bushings
Energy Cartridge emulators
GSXR steering damper
AllBalls steering head bearing conversion
4-into-1 clipon handlebars & coke bottle grips
Brake Modifications:
Drilled and skimmed front rotor
Gremica remote master cylinder hidden under tank
Custom brake hoses, levers, and cables
Drilled rear drum housing
Speedy Seigl Racing aluminum brake stay
Aluminum and carbon fiber rear brake actuator
Drilled rear CJ pedal
Electrical Modifications:
High output 5ohm ignition coils
Custom wiring harness
Anti-Gravity lithium battery
Speed Moto Co. Led headlight
Prism Motorcycles USA Led tail light
« Last Edit: Nov 19, 2018, 14:57:16 by MiniatureNinja »
Offline Sderbyshire
  • Into Sailing, classic Triumph cars and motorbikes.
« Reply #2 on: Aug 20, 2018, 06:29:41 »
N I C E !
Offline cb360j
« Reply #3 on: Aug 23, 2018, 13:28:22 »
What did you do as a license plate bracket?
« Reply #4 on: Aug 23, 2018, 20:41:53 »
Just Some aluminum angle, cut it to mount over the upper shock mount and holds the tag, stop/tail and tag light
Offline Sderbyshire
« Reply #5 on: Aug 24, 2018, 02:52:43 »
Just noticed the coils, look cool !
Might need a new set of coils myself, and like the look of these, where are they from ?
Steve
Offline WhyNot
  • ~~~If it ain't raining, I'm riding~~{iii}?~~prost~
« Reply #6 on: Aug 24, 2018, 10:13:23 »
When you say modified exhaust header, can you go a little more in depth?
Thanks
Bike looks great.
2015 Toyota Taco DD now
2006 Harley Davidson Heritage Softail
1975 Honda CB750K5 needs carb work
1974 Honda CB350F2 needs tins painted (being lazy)
1972 Honda CB175K2 roller no engine
1972 Honda CB/CL350 Engines need roller
1972 Honda SL350K2 Frame for above engine
1972 Honda CB100K2 needs kicker shaft
1990 Mitsubishi MM runs, but no power
1984 Dodge D50 Beater was DD since 1997
Offline irk miller
« Reply #7 on: Aug 24, 2018, 18:26:16 »
if only I could find some fuel hose that didn't yellow after a week, and figure out why my K&N filters turn gray and dry out after 2 days :(
You can get tygon pvc fuel line in a bunch of colors, just not clear.  I use the grey stuff.  Motion Pro brands some.
https://www.amazon.com/Motion-Grey-Motorcycle-Tygon-Fuel/dp/B078WG8DHK/ref=sr_1_fkmr1_4?s=automotive&ie=UTF8&qid=1535145954&sr=1-4-fkmr1&keywords=Motion+Pro+-+12-0031+-+Premium+Fuel+Line
« Reply #8 on: Aug 24, 2018, 22:56:40 »
Thanks
Bike looks great.
I used a set of cj headers, and welded on about 18" of straight 1-5/8" tubing. I plan to merge these and use a single cone engineering muffler or just two cheaper emgo mufflers angle up similar to the supersport bikes
« Reply #9 on: Sep 22, 2018, 00:13:13 »
showed up the last bike meet of the year and no one was there. took a couple photos. then went and planned my own bike meet with friends.
