Author Topic: 1975 CB250 Engine Swap  (Read 512 times)
Offline waldo101
« on: Sep 29, 2018, 21:13:25 »
Hello everyone,
I have a 1975 Honda CB250. I have never had this bike running but from looking at the engine I am sure it’s been thrashed out and I do not have the budget to rebuild it. Would it be possible if any other engine would slide straight into the frame? Newer preferably
Offline Hurco550
Re: 1975 CB250 Engine Swap
« Reply #1 on: Sep 29, 2018, 22:04:48 »
I don't have an definite answer, but may be worth looking into a rebel 250 lump. Stateside they are cheap as chips and fairly reliable too.
~ bradj
Offline waldo101
« Reply #2 on: Sep 30, 2018, 01:16:00 »
I am located in Australia and I think they are a bit harder to come across here unfortuanlty, do you know if the newer cb250 engines slide into the same frame?
Offline Brodie
  • Gold Coast, Queensland
« Reply #3 on: Sep 30, 2018, 01:30:06 »
Hey mate. I think you probably would be better off checking your engine before you decide to replace it. A swap might sound easy but keep in mind you will need to replace the carbs, CDI and a host of other things if you go to a newer engine.
Judging by your build thread it is one of the export CB"250" that the UK and Australia got. A small bore CB350 to meet the learners regulations of the time. Not much in common with any other the other CB250s.
You should be able to get a CB350 top end for it and there is a wealth of knowledge here for rebuilding them.
Either that or any engine that fits in a CB350 frame should work.
« Last Edit: Sep 30, 2018, 01:47:50 by Brodie »
Offline Hurco550
« Reply #4 on: Sep 30, 2018, 20:35:28 »
With a "bit of work" an xr600 single will fit the 360 frame. Not a bolt in operation, but far from impossible. I've been slowly gathering parts for a similar project. Here's a good write up.
http://www.chopcult.com/forum/showthread.php?t=20728
~ bradj
Online ridesolo
  • You only bear responsibility for your own actions
« Reply #5 on: Sep 30, 2018, 21:18:16 »
Hello everyone,
I could be wrong, but I believe the CB250 of that vintage were, as stated above not sold in the US.  However from what I've seen and based on the year, I believe they were based on the CB360.  I don't know if the CB250 and CB360  share the same bottom end and case and just have a different top end or if the entire engine was different.  My point is that w/ a little more investigation you MAY find that the engine from a CB/CL360 may just bolt right into your frame.  You might try writing CrazyPJ, I'll bet that if anyone on here knows for sure it'll be him.
“Fight on and fly on to the last drop of blood and the last drop of fuel, to the last beat of the heart.”
— Baron Manfred von Richthofen
Please check out:  http://www.VetTix.org
This is cooking away out in the shop:
'75 Honda CL378: http://www.dotheton.com/forum/index.php?topic=56547.0
This one is FINALLY done: (!)
'70 Rupp Roadster: http://www.dotheton.com/forum/index.php?topic=67459.0
