Author Topic: Post a pic of something you made!  (Read 1778 times)
Offline ncologerojr
    • Catskill Mtn. Customs
Re: Post a pic of something you made!
« Reply #10 on: Oct 11, 2018, 15:15:43 »
I've got a few things I'll toss up.
 1st is velocity stacks that mount actual air filters.
2nd is hydraulic clutch slave for an xs650
3rd is hub/rotor adapter to use a cb550 hub and ducati rotor with a zx6 big piston fork front end
And last is a tube bender using prints from this site http://chopperhandbook.com/bender.htm
I did use a waterjet for part of the tube bender, and a cnc lathe for the velocity stacks.  But the others were done on an old atlas lathe and a manual mill.
Nice work. I love spending time on my south bend and manual Bridgeport, but I would put a water jet and cnc to use if I could!
Online Rat_ranger
« Reply #11 on: Oct 11, 2018, 16:22:42 »
Thanks, I just took advantage of working at a company that built water jets, then when I changed jobs I ended up programming and running a pair of live tool lathes.  Now I have a better job, but can't run anything under the table.  Now I'm limited to an Induma mill, and the old atlas 10".  But after seeing the work bench posted earlier I need to quit waiting and build a better one.
Offline LMCol
« Reply #12 on: Nov 18, 2018, 13:09:49 »
Not really "made," but I've been tinkering in solidworks after work for the last few days knocking up a hossack front end concept. Haven't done any proper linkage calcs so don't read too far into the kinematics. Also, I know belt driven steering is a bit on the sketchy side...
I'm planning on doing an actual hossack build probably next year, but it'll be all tubular steel. This is just a bit of fun.
« Last Edit: Nov 18, 2018, 14:12:59 by LMCol »
Offline hooligan998
« Reply #13 on: Nov 19, 2018, 01:32:33 »
No fancy metal work or anything going on here, but I made my own damping rod holder out of 1" PVC.  I heat the end with a hot air gun until pliable, forced it over the end of the cartridge until it set and then ran it under cold water to harden it.  Then I drilled a hole through at the other end to stick a screwdriver through to help hold it in place while you loosen/tighten the bottom bolt.  Works great.  This was made for a set of 43mm standard forks.
I got the idea from another forum I'm on.
Offline Hoofhearted
« Reply #14 on: Dec 19, 2018, 02:22:37 »
Does this count?
El Mirage record 500 APS/PG 129.817
El Mirage record 500 SC/PG   122.240
El Mirage record 500 SC/PF    120.157
Bonneville record 500 SC/PG  119.667
Bonneville record 500 SC/PF   117.186
Bonneville record 500 SC/PBG  111.494
Bonneville record 500 SC/PBF   112. 600
Bonneville record 650 SC/PF   128.703
El Mirage  record  650 SC/PG   130.224
Offline Ichiban Moto
  • Bad Ass Cafe' Style
    • Ichiban Moto on Youtube !
« Reply #15 on: Dec 19, 2018, 09:54:06 »
I made a badass vapor blaster:
Offline canyoncarver
  • 'hacking is learning'
« Reply #16 on: Dec 19, 2018, 11:34:23 »
« Reply #17 on: Feb 04, 2019, 12:38:08 »
I just got my shovelhead split tanks repainted so I need a new tank bib.  I went to Tandy leather, they give a great discount to military, vets, and first responders.  I got a few leather punch tools, needles and things.  I got some new leather and lacing and did this over a weekend.  They even had some cool pins that were perfect for what I wanted.
Offline Maritime
« Reply #18 on: Feb 04, 2019, 13:12:22 »
Nice job.
« Reply #19 on: Feb 04, 2019, 13:31:28 »
