Author Topic: SR 250 Mono Build  (Read 1856 times)
Offline Brodie
  • Gold Coast, Queensland
Re: SR 250 Mono Build
« Reply #10 on: Oct 24, 2018, 15:07:29 »
Yep. I know the feeling. They do bump start well though. Just make sure the carb is in good tune and you should be right with a 4 cell.
« Last Edit: Oct 24, 2018, 22:11:14 by Brodie »
Offline 2Planks
« Reply #11 on: Oct 25, 2018, 11:12:27 »
Anyone know where I can find the riser dampener? Looking for the rubber insert with the metal sleeve the riser bolt goes thru?
"I'd take years off my life, before life off my years"
Offline Hurco550
« Reply #12 on: Oct 26, 2018, 11:47:50 »
usually a local Yamaha dealership. Looks like your in Denver, so I just searched the parts fiche at that vickery which appears to be a Yamaha dealer in Denver. Unfortunately it appears that they do not sell just the dampers separate from the top triple, which leads me to believe that they may be cast into the triple and non replaceable. I am not sure of this though, as I have never boogered with a sr250 before.
http://shop.vickerymotorsports.com/fiche_section_detail.asp?section=1140537&category=Motorcycles&make=Yamaha&year=1981&fveh=30686
~ bradj
Offline 2Planks
« Reply #13 on: Oct 26, 2018, 12:14:52 »
I don't know why I didn't think of that! HAHA thanks man they had them and are on there way!!
Offline 2Planks
« Reply #14 on: Oct 30, 2018, 10:44:52 »
I thought it was Jadus on here that had some posts on removing the bottom bolt from the fork. I believe its just spinning took all my brain power engineering tools to get the caps off.  Was It Cosworth that had a post on fork rebuilds? any help  thanks guys.
Offline irk miller
« Reply #15 on: Oct 30, 2018, 11:47:40 »
After I've pulled the spring out and drained them through the top cap, I take a broom stuck cut down a few inches above the top of the fork tube, taper the end of it, then hammer it into the the hole in the damper rod.  There are other ways to do it, but that's what has always worked for me.  You just need something to hold the damper rod, which is what the screw at the bottom of the fork is holding.
Offline 2Planks
« Reply #16 on: Oct 30, 2018, 12:00:23 »
Thanks ! My impact drill will be here tomorrow. I will craft something up! appreciate the help.
Offline pidjones
« Reply #17 on: Oct 30, 2018, 19:32:40 »
I just use my air impact and a hex bit BEFORE taking the rest apart (drain it of course). The spring holds it enough to prevent spinning.
Offline 2Planks
« Reply #18 on: Nov 01, 2018, 09:30:56 »
Got the forks apart last night. Use a bolt extractor bit to hold the dampener rod in place. Will find some thing to fit the top of it for the re install. These shocks are in rough shape haha. Also started to prep my frame for welding. I think I check the tracking info every ten min.
Debating on putting a spacer or not any thoughts on putting it on top or bottom?
Also finger is healed from the cut off wheel. Don't take the guard off its there for a reason.
Offline 2Planks
« Reply #19 on: Nov 13, 2018, 09:12:59 »
Made some progress on the bike yesterday! Got the top shock mount pieces cut out. As well as a brace, built the seat as well. Other than than my welds needing some practice i'm happy with the ways its coming along. Still need to decide where I want my seat to come back, am thinking of keeping it parallel with the bottom of the tank( a little high in the pic). Still need to make some more braces. Also make the tank mounts.
Questions,
Should I brace the swing arm? I think it will be fine.
Not a frame question but I started to de-lace the rims. Spokes will need to be replaced. Anyone know where I can get some spokes?? Also debating on bumping up the rear rim to an 18"? Thoughts?
