Author Topic: aftermarket ignition switch not working  (Read 518 times)
Offline Rywilly
« on: Nov 05, 2018, 21:28:47 »
Hey all,
I got a lower profile igintion switch to improve the look of my 78 GS550, it was supposed to plug in no problems, as far as I know. Plugged it in to the existing plug on the harness and my gauge turns on, but nothing else, and it seems its backward. When the key is in the off position the gauge turns on, but when its in the on position everything turns off...
any insight, bad ignition switch, or is it me?
78 GS550E
Online irk miller
Re: aftermarket ignition switch not working
« Reply #1 on: Nov 05, 2018, 21:31:39 »
Do you have a multimeter that tests for continuity?  I would start testing your wires.  Could be as simple as bent tabs on the connectors.  I have also gotten handlebar switches wired wrong.  Usually the turn signal wires are swapped.  So, that is certainly a possibility.
Offline Rywilly
« Reply #2 on: Nov 05, 2018, 21:34:51 »
If the turn signals wires are swapped that'll do that?
78 GS550E
Online irk miller
« Reply #3 on: Nov 05, 2018, 22:59:18 »
No, I'm just saying I have gotten switches where things are wired wrong.  I figured it out with a meter, and of course my lights flashing opposite.
Offline Rywilly
« Reply #4 on: Nov 08, 2018, 00:02:00 »
Got the wires un-crossed as far as I can tell, but now bikes not turning over - its a four wire ignition switch but aftermarket.
78 GS550E
Offline WhyNot
« Reply #5 on: Nov 08, 2018, 08:53:05 »
Got pix.............? ? ? ?
Did it fire b4?
Do the wire colors on the switch pigtail match the wire colors on the harness.
I had one that didn't, change them to match, viola.
2015 Toyota Taco DD now
2006 Harley Davidson Heritage Softail
1975 Honda CB750K5 needs carb work
1974 Honda CB350F2 needs tins painted (being lazy)
1972 Honda CB175K2 roller no engine
1972 Honda CB/CL350 Engines need roller
1972 Honda SL350K2 Frame for above engine
1972 Honda CB100K2 needs kicker shaft
1990 Mitsubishi MM runs, but no power
1984 Dodge D50 Beater was DD since 1997
Offline Rywilly
« Reply #6 on: Nov 08, 2018, 18:56:25 »
I'll have to add photos. It did start right up before, I think the switch is meant to be rated for 25 amps? Not sure this one is.
Any ideas on that? Looking for one which will fit my new custom set up - just not sure which ones out there would work.
Is the 25 amps the significant info?
78 GS550E
Online irk miller
« Reply #7 on: Nov 08, 2018, 18:57:50 »
It matters if it burns up a contact.  Test continuity with a meter will tell you that.
