Author Topic: SR500 RACE BIKE - Tracy body kit - Survivor - Ohio  (Read 8581 times)
Offline imwastefull
Re: SR500 RACE BIKE - Tracy body kit - Survivor - Ohio
« Reply #100 on: Jan 02, 2019, 15:32:14 »
Looks like a '95-'97ish GSXR part just like the front end and wheels.
https://www.ebay.com/itm/1995-SUZUKI-GSXR750W-FRONT-BRAKE-MASTER-CYLINDER-W-LEVER/292477260722?hash=item441900d3b2:g:1qMAAOSwGltaot~Y
I might just buy a chinese or brembo job from the ebay. We'll see.  :-\
Offline Streetfighterkz
« Reply #101 on: Jan 02, 2019, 16:53:29 »
I would/will NEVER buy anything brake related from the Chinese.  I’ll save and pony up the extra $$ for something reputable. Brakes aren’t something to skimp on.
Just my $0.02, but I could be wrong.
Later, Doug
'78 Kz1000
'76 Kz900 'Stripfighter (work in progress)
'83 Gpz750 (work in progress)
'89 V-Max
'89 Gsxr750 Trackfighter
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #103 on: Jan 02, 2019, 17:31:18 »
I used a new $25 Chinese Grimeca knockoff master on the CB360. It said Grimeca on it, but it was $25...so I assume it was a knockoff.
It worked fine and never leaked in the 2-3 years I had it on the bike, for what its worth.
Offline 1fasgsxr
« Reply #104 on: Jan 02, 2019, 18:05:32 »
Some of the newer R1's came factory with a Brembo master cyl. It was a single year or a very short year run on them. They used radial calipers too...not sure if that would make much difference.
You can buy a used master off eBay for really cheap. Even if it needs a rebuild you know what to get as far as parts go.
Offline teazer
« Reply #105 on: Jan 02, 2019, 18:21:18 »
What size is that M/C?  It should be cast into the body.  I'd look for one the same size as that one which is most likely a GSXR 5/8" unit.
You could also clean that one out and fit a banjo bolt with bleed nipple to make life easier.
Offline 1fasgsxr
« Reply #106 on: Jan 02, 2019, 18:28:05 »
It looks similar to the one on my 98 Gsxr. I think they were the same on many Gsxr's.
Offline pidjones
« Reply #107 on: Jan 02, 2019, 18:39:46 »
Chinese masters are Ok if you clean/assemble properly before installation. At least the one front and one rear I've used. Issues were found but easily corrected on both.
Offline imwastefull
« Reply #108 on: Jan 02, 2019, 18:55:50 »
Yep, this is a 5/8" master. I've seen those bleeder banjo bolts, I wanted one but its another chinese jobby. I'm going to tinker around, rip it apart, and try and find the problem. If it can't be sorted in a couple hours, i'll probably buy a cheap chinese master though.
I've never heard of the Grimeca units... (I'm a dumb harley guy) anyone have a link? I'll have to do some research.
Offline doc_rot
« Reply #109 on: Jan 02, 2019, 21:33:39 »
Ive used the Chinese MCs many times when flipping bikes. They work fine for $20 shipped, but the finish is very poor and I have had the reservoir caps leak on two of them.
brand new basic Brembo 16mm MC is $100 brand new. Nothing fancy but the fit and finish are excellent.
« Last Edit: Jan 02, 2019, 21:37:02 by doc_rot »
