Author Topic: SR500 RACE BIKE - Tracy body kit - Survivor - Ohio  (Read 6688 times)
Offline imwastefull
Re: SR500 RACE BIKE - Tracy body kit - Survivor - Ohio
« Reply #20 on: Dec 05, 2018, 09:38:16 »
I heard praytell that there is a simplified wiring diagram on rexs-speedshop.com but i couldn't find it for the life of me.
I was able to find these simple diagrams - https://www.flickr.com/photos/bcm-blog/sets/72157615127432489/
couple questions; In the diagram, they keep saying magneto. Do they mean that as the charging system? In my world a magneto makes spark for an old harley.  Also, are all sr500's a CDI ignition? mine is a '78.
thanks!
Offline der_nanno
  • Faster!
    • Greasy Greg
« Reply #21 on: Dec 05, 2018, 09:48:30 »
The mystery box is the stock VM34SS accelerator pump. Yes, the bike runs a self-exciting coil (kinda like a magneto), so you don't need a battery to have spark. Downside, one of the coils is a very fine wire 300 Ohm coil prone to shorting out, which means you end up with no spark below 2000-something RPM. (That's when the other coils kick in and produce the electricity for the ignition.)
Unfortunately for SR500s, you simply speak the wrong language, if you want support - time to brush up that German, but google translate will help you through the worst.
In order to bypass the stock induction setup, there's a so-called two-wire setup to check out the rest of the electrical system:
http://motorang.com/bucheli-projekt/elektrik_allgemein.htm#zweikabel
That being said, if you need parts, look into the direction of http://www.kedo.de
And yes, the SR500 has always been CDI driven, you can convert it to points, if your really wanted, but that's only possible, when you still have an older set of cases, which still has the casting pre-drilled for the points shaft and gear. Plus you will need a XT500 clutch-cover and points-setup. (Some german racers use that in the Grab the Flag Classic 500 series, aka. SR500 cup (www.grab-the-flag.de) and because you will surely wonder about it... tuning is rather sophisticated, with the best bikes running around the 50 to 55hp (at the rear wheel of course) )
If you need info on hot-cams, short stroke conversios, different carbs, bigger valves, altered combustion chambers... well, I'll keep an eye on this thread here.
Cheers,
Greg
My Blog:
Offline Hurco550
« Reply #22 on: Dec 05, 2018, 09:55:52 »
whereabouts ya live in ohio?
~ bradj
Offline imwastefull
« Reply #23 on: Dec 05, 2018, 10:24:03 »
Der Nano, my man! That diagram is perfect! thanks for the help, brother. I'm going to give her hell to get running this weekend. I'd really like to know what state the engine is in before I proceed fixing anything else.
Hurco, I'm in the Akron/Canton area.
Offline JustinLonghorn
« Reply #24 on: Dec 05, 2018, 10:30:28 »
I am in. I really enjoy the Tracy body on this scoot.
Into The Sunset, CB750 build
TT500 the Animal
Offline Hurco550
« Reply #25 on: Dec 05, 2018, 11:31:54 »
Ah cool, sis went to college there at Malone University. I'm just down by Marion. Cool project man!
~ bradj
Offline CrabsAndCylinders
« Reply #26 on: Dec 05, 2018, 12:09:38 »
Lighter, Quicker, Faster.
Offline teazer
« Reply #27 on: Dec 05, 2018, 13:13:40 »
That makes sense.  If that is what it is, then there should be two fuel lines - one from the tank and the other to somewhere on the carb where it discharges.
Offline imwastefull
« Reply #28 on: Dec 05, 2018, 15:34:01 »
Man, I wish my swingarm was Motolanna. They're real nice. Mine is less elaborate and uses the stock chain adjusters.
Offline imwastefull
« Reply #29 on: Dec 05, 2018, 15:36:23 »
Peep the custom bluetooth sprocket bolts.  8)
This whole bike is (at best) loosely attached.
