Quantcast
Author Topic: SR500 RACE BIKE - Tracy body kit - Survivor - Ohio  (Read 9896 times)
Offline imwastefull
Re: SR500 RACE BIKE - Tracy body kit - Survivor - Ohio
« Reply #60 on: Dec 07, 2018, 14:56:01 »
You are probably running the correct caliper.
That fork style are found on 92-93 Gsxr600W, 90-95 Gsxr750, and 90/91(?)-98 Gsxr1100s.
thanks boys!
Offline imwastefull
« Reply #61 on: Dec 10, 2018, 19:17:43 »
Not much to add, just waiting on parts. Bought some tank cleaner to sort the rust and snagged some brake lines to get that going. If all goes well, I'll take her around the block before tear down.
While we wait, take a look at this custom Grinch flavored carb guts. 😬
Offline der_nanno
  • Faster!
    • Greasy Greg
« Reply #62 on: Dec 11, 2018, 02:28:02 »
Two things I can tell you with this carb:
1) this isn't the stock carb (but I guess you figured that out already) - would be interesting to see if it's a 36 or 38mm
2) This has not been run on alky as otherwise the mainjet would be VASTLY bigger.
My Blog:
Offline imwastefull
« Reply #63 on: Dec 11, 2018, 09:00:14 »
You know, I meant to measure the carb while I had it out. I was curious as well. I still have to pull it and give it a proper scrub so I'm sure I'll put the calipers to it. I was just amazed at how green the bowl was. It blew my mind.
Offline cxman
« Reply #64 on: Dec 11, 2018, 10:19:26 »
i wonder why it has the remains of a power jet on it? might be left over from a 2 stroke applicaton
1978 CX650 Super Deluxe
1979 XS1100 Special
1974 xl350
1983 cx650 Custom
1973 cb750
1980 cb750
1981 cb650
1982 cb900 c
1974 kawasaki 350 bighorn
1983 GL1100 aspy full dress
1983 GL1100 Nekid
and a bunch of others
Offline teazer
« Reply #65 on: Dec 11, 2018, 10:33:15 »
That "power jet" was apparently connected to an aftermarket accelerator pump.
Offline cxman
« Reply #66 on: Dec 11, 2018, 21:10:55 »
i would like to see that
1979 XS1100 Special
1974 xl350
1983 cx650 Custom
1973 cb750
1980 cb750
1981 cb650
1982 cb900 c
1983 GL1100 Nekid
Offline imwastefull
« Reply #67 on: Dec 11, 2018, 21:16:50 »
You just have to scroll back a couple pages, bud.
Offline imwastefull
« Reply #68 on: Dec 14, 2018, 18:37:51 »
Chem dipped the shit out of the carb, rear master(which was frozen) and the petcock (which was ALSO frozen). They cleaned up pretty well and hopefully I won't have to buy a new petcock.
Bought a Kreem tank liner kit to clean and line the rusty tank. However, after letting the acid sit overnight, I drained it and it was the water ran out clear! Righteously confused, I rinsed the tank out and put a magnet to it and found out it isn't metal! The tank has a steel fuel bung but the whole tank is fiberglass. I'll post a picture so you can see for yourselves.
Also, I found out the mikuni is a 36mm. I was really pulling for a 38mm. Bummer. 😬
Offline teazer
« Reply #69 on: Dec 14, 2018, 20:10:29 »
Yep.  Tracey bodies were all fiberglass.
